11-14-2024, 01:45 PM | #1 |
Junior Member
Steering road sway
At the start of my dad's 72 c/k 20 resto I had road sway or wandering with the steering and the excessive movement needed in the wheel to keep it on the straight and narrow was a *****. I have 33s on it and wondering if other components are needed to bring it back to instant compliance. I had went to the steering box and to remove any play in it. I am putting a new rag coupler on the steering shaft
The ball joints are still the originals and they are going to the trash. Anyone run into this by just installing bigger tires ? Or am I going with a fresh steering box as well Thanks all |
11-14-2024, 04:35 PM | #2 |
Re: Steering road sway
How much air pressure in your 33’s?
11-14-2024, 05:00 PM | #3 |
Junior Member
Between 32 and 36 psi
11-14-2024, 05:04 PM | #4 |
Maybe you already have but I would take it to a alignment shop and see what the caster/camber/toe are at. They can also check all the steering linkages for play.
I would hold off on the new steering box until you have checked/adjusted everything else. |
11-14-2024, 05:43 PM | #5 | ||
"I ain't nobody, dork."
is it a C or a K truck? You listed both... big difference in suspension. Assuming a K since you have 33's
Gary
11-14-2024, 05:58 PM | #6 |
Junior Member
It's the 3/4 ton 8 lug axles . It's the k20 and longbed.
I will start at the rag joint then pitman arm for lag Then the tie rod ends to each knuckle Lastly the ball joints I think that should point me in the right direction I had a friend with a lifted jeep with oversize rubber Did the same with the steering. Which led me to think a different steering part was was needed to compensate for the lift/tires. |
11-14-2024, 06:19 PM | #7 |
20' Daredevil (Ret)
Something else that can affect steering (other than lift / tires) is wheel offset / backspacing.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
11-14-2024, 09:29 PM | #8 |
You might want to look closely at the frame where the steering box bolts on. It's not uncommon for the K models to crack as allow the steering box to flex.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
11-14-2024, 09:51 PM | #9 |
Junior Member
Great replies. The box mounts I should be easily to spot.
The back spacing is interesting. I wonder what a acceptable hub to rim distance is before the sloppy steering begins. I will pull a rim and measure the rim mount to the outer rim lip and see what I get. I was planning on blasting the white wagon rims and repaint and reuse. That may be the issue. Anyone provide SAFE backspace limits ? |
11-14-2024, 09:55 PM | #10 |
Junior Member
Current wheels are 33 x 12 5r x 16.5 if that helps.
11-14-2024, 10:24 PM | #11 |
Who Changed This?
Do you have a steering stabilizer installed?
11-15-2024, 12:11 AM | #12 |
When I first got mine, it wandered all over the road. With the truck parked on level ground I had someone move the steering wheel back and forth and I looked for excessive play/movement in any joints. Lots of play at the drag link and tie rod ends. Since it is a K truck, worn spring bushing can have a huge effect. Mine were worn to the point that moving the steering caused the whole truck to shift side to side while the front axle stayed in one place. I also tightened the bolt/nut that clamps the pitman arm to the steering gear shaft. Fixing those 4 things made the truck steer and track much better.
1972 GMC K2500 Super Custom Matt |
11-15-2024, 11:57 AM | #13 |
I work on school buses for a living...
The slightest amount of looseness in ANY steering component can be a problem. Checking the tie rod ends and drag link cannot be judged by pushing on them with hand strength . You can take a pair of channel locks and squeeze the joints together. If there's ANY looseness or movement, that component is bad. If your pickup is 502 years old, it might need some parts??? Last edited by 68Gold/white; 11-15-2024 at 12:00 PM. Reason: bla |
11-15-2024, 12:29 PM | #14 |
Junior Member
The truck is stock height
It has a stabilizer on It. So at 53 yrs old, the rag joint, ball joints t rod ends and spring bushings are heading to the trash. Thanks for the Red Head steering box info. Since I will have a rolling frame to call it restored is a lie without a full front end component replacement. With all the info provided, I'm pretty sure you all have solved my problems and will proceed with fresh parts. If there is still a issue I will be back with my list of things done and if the problem is solved. I watched Fantom Works.do a 59 Apache and the f spring perches moved slightly which they determined was by GM Design |
11-15-2024, 12:50 PM | #15 |
Junior Member
I have the Svc and Assembly manuals and I came across front end adjustable spring shackle stops. I never noticed them before. That's another are for me to look at. They may be rotted or missing.. page 3-8 in the Svc manual. It allows for 1/8 clearance.
11-15-2024, 02:13 PM | #16 |
Junior Member
I found a original GM shackle stop kit from OLDSMOBILE OBSOLETE.
The part # is 325077 Comes with the weld on strap and rear bolt on stop plate. |
11-15-2024, 03:07 PM | #17 |
Junior Member
After my dad passed, the truck sat before it was driven again. It just hit me that he had rewelded the front shackle stop plate to the spring mount. Wow what time does to a memory. Dollars to donuts that it rebroke or is gone completely .
I'm going out to look as I may be looking to deep into a simple solution |
11-15-2024, 03:50 PM | #18 |
Junior Member
Well, wishful thinking. My dad did a OEM weld on the stopper and the rear stopper is still in place.
I would like to thank you all for your help, tips and suggestions. I move forward with replacing all the bushings, joints rod ends etc etc This site is well worth it |
11-15-2024, 05:49 PM | #19 |
Typically when you add any kind of lift it will mess up the caster. Less caster will make the truck more difficult steering going down the highway. Your truck caster was designed around bias ply tires. Current radial tires need more caster to go down the road straight.
Do you have lift blocks that are cut at an angle to increase caster after the lift? |
11-15-2024, 08:18 PM | #20 |
Junior Member
No lifts. I'm not a fan of them
It only got the 33's and a stabilizer Stock otherwise. It's a matter of new spring bushings, shackles and the rest of the 53 year old front end parts. It's presently tarped with Peppermint sprayed inside the cab and wiring I will have to wait to get it inside to start the parts replacement I imagine this will be a 3yr (hopefully) time frame. I have to replace the complete floor and cut the roof at the A and B pillars and weld in the primo one I cut off a C10 Mine came stock with the roof marker lights and I have transfer those as well |
11-15-2024, 09:14 PM | #21 |
Sorry I missed the stock ride height.
Good luck with your project. |
11-16-2024, 08:42 AM | #22 |
Junior Member
No worries. I do tend to skip.parts of a text and then reread only to.find I jumped a sentence
I with all the comments, I surely will find the issue This site with all the members who are sharp as tack on this gen of trucks never going to Google for answers |
11-16-2024, 12:47 PM | #23 |
Make sure you check the toe I set mine in at 1/16"
California 65 GTO---Texas 64 burb 283 ---Oklahoma 67 CST SWB BBW wood bed 327 2004r---New Mexico 72 k10 350 350 auto---Georga 72 short step project |
