Old 11-30-2024, 11:35 AM   #1
freak
Are there disc brake kits for the K20?
...or is everything out there for K10's?
freak is offline   Reply With Quote
Old 11-30-2024, 01:19 PM   #2
1970cstblazer
1970cstblazer's Avatar
Lightbulb Re: Are there disc brake kits for the K20?
None that I am aware of. If your K20 is a 1969 or older, you will need to engineer a conversion for your closed knuckle Dana 44, or switch it out for a 1971-early 1977 large hub Dana 44. If you have a 1970, then you can switch the knuckles and all related parts from a 1971-early 1977 Dana 44.
1970 K/5 Blazer CST 4WD, Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 11-30-2024, 03:01 PM   #3
57taskforce
All about them K’s
57taskforce's Avatar
Why limit it just to 77? I assume because of the correct style lockouts? Any 71-87(91) GM solid front axle will swap in and work for the conversion.
Tyler
57taskforce is online now   Reply With Quote
Old 11-30-2024, 03:26 PM   #4
freak
Ok thanks I appreciate it. I'm looking for a 1967 K10 right now but I'd take a K20 if that's all I can find. Might even have to start with a C10.
Old 11-30-2024, 05:12 PM   #5
dennislbrooks
dennislbrooks's Avatar
As 57taskforce proposed. I used an 88 Blazer corporate 10 bolt up front in my 67 K10 (was c10) and an 84 pick up front in my 59 now 4wd- I think Dana 44. Both 3.73 gearing.
1942 Chevy 1/2 ton Rod, 1959 GMC 1/2 ton Fleet Stepside, 1967 Chevy SWB K10, 1985 Corvette Coupe 4+3, 2015 Chevy Duramax reg cab 4WD W/T
dennislbrooks is offline   Reply With Quote
