Old 11-30-2024, 06:10 PM   #1
540ChevyC20
Vented fuel cap for non-vented gas tank - '72 C20
Hi All,
My '72 C20 (originally 402 BB) has a non-vented gas tank. I've been trying to find the correct fuel cap for it - it needs to be vented. I've purchased fuel caps both from AutoZone and LMC truck - both look identical - see pic below. Neither seem to be vented as every time I go to fill up with gas there's a loud "whoosh" as I remove the fuel cap. Would somebody be able to point me to the correct, vented fuel cap for a non-vented gas tank? A pic would be hugely appreciated too if you have one. Thanks!
540ChevyC20 is offline   Reply With Quote
Old 11-30-2024, 07:00 PM   #2
72c20customcamper
72c20customcamper's Avatar
Re: Vented fuel cap for non-vented gas tank - '72 C20
NOS originals show up from time to time on the sale forum I bought two last year
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
72c20customcamper is online now   Reply With Quote
Old 12-02-2024, 12:51 PM   #3
70STOVEBOLT
70STOVEBOLT's Avatar
Your pic looks like a vented cap to me. Same style as on my '70.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 12-02-2024, 01:27 PM   #4
sixty8HDC30
Like 70stovebolt said, it is a vented cap. however it's only vented one way meaning the tank can build pressure but it wont hold vacuum. This is correct for our trucks and most vehicles. when you take a newer vehicle for a smog test they always check that the gas tank and the gas cap hold pressure, hearing a whooshing sound when you remove the gas cap is normal.
____________________________________
1968 Chevrolet C-30 327 4spd flat bed dually 157" WB
1997 Chevrolet k1500 5.0 auto ECSB
sixty8HDC30 is offline   Reply With Quote
Old 12-02-2024, 04:46 PM   #5
72c20customcamper
I had one of those “vented “ caps on my 68 it built up so much pressure I heard the tank bulge . Made a hell of loud bang I took it off and found some NOS ones
This is the one I had I tried two of them same result way to much pressure.
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 12-02-2024, 05:21 PM   #6
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
I had the impression 1972 models had "vented" caps. I know my 1971 EEC didn't, vapors captured by the canister and so forth.
The 70-71 EEC called for a different cap than 1972, however, that doesn't mean 72 weren't built using up 71 stock.
FWW, I had a 72 402/400, but I didn't study the tank. It did blow vapor after installing an aftermarket, I just got a dependable aftermarket instead, with no problems. It was a driver, so I only cared it worked. It was a "vented cap". If it had a canister, which I'm positive it once did, everything vapor had been removed. Regardless as mentioned, 1971 Vs 1972 caps differed. For at least some applications, anyway, because the 72 caps "vented".
Check your vapor lines and canister BTW?
Here's what I think is the best explanation for the "unvented" 1970-71 caps:
"the cap has a pressure check valve; the cap allows air into the tank as fuel is used, and only releases air when pressure rises above 3-4 PSI. Fuel vapor otherwise expands into the vapor canister.".... Note trucks with lower side moldings call for a stainless fuel cap. Otherwise the caps were painted, though perhaps not as a rule.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly kit for restoring the (a) truck from the ground up. My build thread, and more on the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 12-02-2024, 06:19 PM   #7
1970cstblazer
1970cstblazer's Avatar
The aftermarket caps are trash. The only ones that work as designed are GM NOS. The 1972 3/4 tons and up use the same caps as the non-RPO NA9 evap emission control 1970 and older trucks.
1970 K/5 Blazer CST 4WD, TOTM winner December 2024! Medium Bronze, 93k ACT. miles, 350, 4 speed, rear positraction, 16.5" x 8.25" HD wheel option, tilt, tach, vacuum, AM/FM, manual throttle...Dad ordered and purchased new 4/70. Currently frame off restoration finally getting close to completion..
1972 Cheyenne Super 20 2WD, DK Blue/White, 90K ACT. miles, 402, TH400, 4.10 open, tilt, tach, vacuum, A/C, AM/FM, manual throttle.. A mostly original paint never rusted Texas survivor...
2017 Sierra 1500 SLT 4WD, Black, 45k miles, 5.3, 6L80E, 3.42 LS, 20" polished wheels, everything but moonroof and 6.2...
2019 Canyon SLT 4WD, White, 62k miles, 3.6, 8L45, 3.23 LS, 18" wheels
Old 12-02-2024, 06:29 PM   #8
HO455
HO455's Avatar
This thread should help you ID the cap you need. Member ClassicBowtie may have one in his stock.
Good luck!
https://67-72chevytrucks.com/vboard/....php?p=9186244
RIP Bob Parks.
HO455 is online now   Reply With Quote
Old 12-02-2024, 07:11 PM   #9
72c20customcamper
My 72 c20has a vented cap, no canister
Mark
1969 AMX ,
1977 Suburban sold
68 anniversary.
Old 12-02-2024, 07:29 PM   #10
540ChevyC20
Thanks for all the replies and useful info guys! In fact I found what I believe is an original vented cap on Ebay - it's on its way to me as we speak. It's not NOS and the rubber gasket does appear to have some cracks so I'll just have to see if it leaks. I do like the look of the locking cap in the thread referred to above - that's definitely my fallback plan.
Old 12-03-2024, 12:48 AM   #11
Steeveedee
Who Changed This?
Steeveedee's Avatar
Every locking cap I've bought, the gasket turned to feces in a couple of years and leaked badly. Something to think about. I have a "vented" cap that does hold some pressure. I recall a thread around here where a member reduced the vent spring pressure.
~Steven
Simi Valley, CA
Old 12-03-2024, 01:13 PM   #12
PbFut
I think the vent spring was me. I opened one up as I was having issue with the tank bulging. You could hear it pop out. Opening the cap proved too much pressure. Upon opening the cap I had, there were two springs in it. Set up sort of like a engine valve with the inner vibration spring. I removed the stiffer of the two springs and left one remaining. It seemed provide good result. No leaking cap coming up and down the twisty hill to the house and no pressure or vacuum build up. I would be careful modifying these caps and pay very close attention to tank pressure after doing so. Things can go really bad pretty fast if the cap is not working correctly. Think of how bad it would be to build pressure and have an old rubber line split.
Also, the gasket on new ones can make removing and putting cap back on difficult and likely damaging to the gasket. A very light thin swear of silicone grease on the neck and gasket works wonders.
PbFut is offline   Reply With Quote
cap, fuel cap, gas, gas tank
