Old 12-16-2024, 12:30 PM   #1
1969stepside
1969stepside's Avatar
stepside bed bolts
what size bolts are needed to put the stepside bed back together? i am talking about the bed sides and the head gate i am sure i can order a bolt kit from like lmc but i am also sure i could get them locally from a store as well
Greater love hath no man than to lay down his life for a friend.
Members i Have met
Earl Slick68
1969 Stepside Build thread
http://67-72chevytrucks.com/vboard/s...=1#post4253546
Chevy Trucks the longest lasting most dependable trucks on the road
1969stepside is offline   Reply With Quote
Old 12-21-2024, 12:45 PM   #2
raggedjim
raggedjim's Avatar
Re: stepside bed bolts
Not complete but it should be a good start. The thing I have noticed is every vendor seems to put together kits that will work but may not be 100% correct (I don't really worry about this)
STEPSIDE FENDER BOLTS
(26) PHILLIPS DRV BOLT - 5/16-18 x 3/4
(26) 5/16-18 NUTS
(26) 5/16 SPLIT WASHERS
STEPSIDE FRONT PANEL BOLTS
(10) INDENTED HEX HEAD BOLT - 5/16-18 x 3/4
(10) 5/16-18 NUTS
(10) 5/16 SPLIT WASHERS
https://classicparts.com/chevy-gmc/t...s-fleetside-ss
REAR SILL BOLTS
(10) INDENTED HEX HEAD BOLT - 5/16-18 x ¾
https://classicparts.com/chevy-gmc/t...ching-kit-zinc
RUNNING-BOARD BOLTS
(4) Size unknown
https://classicparts.com/chevy-gmc/t...-bolt-kit-zinc
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743
raggedjim is offline   Reply With Quote
Old 12-21-2024, 04:30 PM   #3
guyryan100
guyryan100's Avatar
If you get stainless bolts and you want them to be mirror finish, you can polish them easily, takes about 30 seconds per bolt.
guyryan100 is offline   Reply With Quote
Old 12-21-2024, 05:43 PM   #4
72c20customcamper
72c20customcamper's Avatar
The bolts can be sourced locally . The only thing I couldn’t find were the offset washers . I ended up buying a kit from a vendor
Mark
1969 AMX ,
1968 c20 stepside ,85 K20
1977 Suburban sold
68 anniversary.
