Old 12-30-2024, 05:38 PM   #1
SDRRACING
SDRRACING's Avatar
Power Door Lock Help
I'm trying to figure out how and where to install a power door lock actuator on my 1955.2 truck. Can it be done with these goofy latches or do I need to convert to the Altman latch. I'm installing a Digital Guard Dawg kit along with their push button start system. Thanks
SDRRACING is offline   Reply With Quote
Old 01-01-2025, 08:49 PM   #2
SDRRACING
SDRRACING's Avatar
Re: Power Door Lock Help
Has anyone done or looked into if you can modify the door to use the door latch assembly out of a Tri-Five car. They utilize a push button to lock the doors and not the handle. I guess I am trying to make the truck more secure but I cannot see how a slim Jim can unlock the door. Yeah I know. A thief that wants anything bad enough is just going to break the glass.
Old 01-02-2025, 12:09 AM   #3
1project2many
The original locks were actually a combination of two locks. Locking the outside handle consisted of turning the lock cylinder in the pushbutton so the button could not be pressed. The door could be opened from the inside but could not be opened from the outside.
Locking from the inside meant lifting the handle and engaging a lock mechanism in the latch. The outside button could press the latch linkage but the latch would not release. The door could only be opened from the inside by releasing the lock to press the handle down.
If you are trying to prevent the outside button from being pressed, maybe it's an easy matter to use a solenoid to slide a blocking device between exterior button and the lock linkage? If you are trying to lock the inside latch you might want an electric lock motor to pull on the door handle rod to lock the door.
1project2many is offline   Reply With Quote
Old 01-04-2025, 02:42 AM   #4
R&B51
I bought the same Digital dog security system, key fob handpush button start and Altman latches for my 51 Chevy truck. I had been trying to figure it out myself, but your question made me go back to their website.
Looks like Altman offers the hardware to make it work, just have to use a solenoid to lock it.
Here’s a link to it. Let me know if it takes you to the gear:
https://triquemfg.com/products/lock-...n-easy-latches
I will look for an install video or instructions as well.
R&B51 is offline   Reply With Quote
Old 01-04-2025, 10:40 AM   #5
SDRRACING
SDRRACING's Avatar
Thanks R&B51. The link took to their lock actuator bracket but I can't figure out how it mounts and works. Let us know what you come up with. I'm not sure of the differences with your 51 door to mine. I'm going to give them a call and see what they can tell me. Sure would like to get rid of the need of a key to lock and unlock my doors. Thanks
Old 01-04-2025, 03:30 PM   #6
Hcb3200
Plenty of videos on the youtube.
Just search altman claw latch 55-59 or 1956 with chevy truck.
Hcb3200 is offline   Reply With Quote
Old 01-04-2025, 09:35 PM   #7
R&B51
Sorry, I sometimes don’t read close enough before I respond.
I noticed that in the description on these brackets, it says:
This kit does not include lock actuators (I bought those separately) and is
***only meant to be used on a 47-51 Chevy***
Let me know if you hear something from them when you call them about your application.
They may also have some information about adapting it to later year Truck
They may also offer a link to some installation videos.
Good luck and let me know what you find out.
Like you, trying to keep the handles and avoid poppers, but wanted electric lock function.
I was ultimately looking for key fob, unlock from the outside on both doors
Plus
Unlock and lock switch on the inside of the door that is overridden by pulling on the handle to escape if needed.
Old 01-07-2025, 12:23 AM   #8
dsraven
when i get to it, I plan to use door latches and handles from a modern vehicle on my 57. cheap at the wreckers and parts are in stock in town. yes, the door needs to be modified to fit the ouside handle and yes the inside handle will be different than stock. but, it will work and any wrecker will have a good used part. install it, mod the linage to work, which is something that doesn't usually wear out, then if the inside handle wears or the outside handle wears it is an easy parts run and gets fixed same day. no wait for aftermarket stuff that kinda sorta works, has a wait time for delivery and is spendy.
just me talking, you gotta decide what to do with your project.
Old 01-07-2025, 11:26 AM   #9
SDRRACING
SDRRACING's Avatar
Thanks dsraven. That's what I was thinking to do also. I have been going through the many project builds looking as well. Let us no what you come up with. Thanks
Old 01-07-2025, 11:34 AM   #10
dsraven
will do. itsgonna be at least summer time before anything gets done on my project though. I have some home reno's to do first.
Old 01-07-2025, 01:48 PM   #11
SDRRACING
SDRRACING's Avatar
I was looking for your project build on this site. I have to get one started on mine. I was looking at the door latches on the trifives and later trucks. They are similar with the exception of the lock feature. I'm curious as to what the guys did that changed out their exterior door handle to the early Camaro handle.
Old 01-07-2025, 05:14 PM   #12
mr48chev
mr48chev's Avatar
I'd just contact Trique mfg. directly and ask. I did that when I was figuring on mixing and matching cab parts for my stretch cab build and though the back half of choice was a 53 cab. They are pretty good about getting back to you with decent answers.
https://triquemfg.com/pages/contact-us
My ongoing truck projects:
Old 01-07-2025, 06:26 PM   #13
SDRRACING
SDRRACING's Avatar
I should've looked a little closer at their web site and the instructions for using a power door lock with their latch. Like the fact that you can still open the door from the inside even though it is locked from the outside. They offer brackets for mounting the actuators for the 47-51 trucks. Going to have to ask them if they have the same for the 55-59 trucks. Thanks mr48chev.
https://cdn.shopify.com/s/files/1/00...f?v=1727105753
Old 01-07-2025, 07:37 PM   #14
mr48chev
mr48chev's Avatar
Those actuator brackets mean that I am going to have to throw another truck unit in the kitty.
Old 01-09-2025, 05:39 PM   #15
SDRRACING
SDRRACING's Avatar
Here's the reply I got back from Trique Mfg. Looks promising on what I want to accomplish using power door locks. Going to order up a Altman latch.
The latch kit we make for the 55-59 Chevy Truck has a lock provision on it that you can use with power lock actuators. When locking the door from the outside, you are locking the button in the handle, so that has nothing to do with the latch. As for the inside handle, with our kit you will still be able to open the door using the interior handle, but the door can not be locked by the inside handle.
They offer brackets for the 1947-51 for mounting the locks. I asked about if they had brackets for the 55-59 trucks.
At this time we do not. Usually people will mount the actuators down low in the door under the latch and run the rod up to the lock lever
Old 01-09-2025, 11:22 PM   #16
mr48chev
mr48chev's Avatar
Thinking on it the other night and looking at the locks and the lock cylinders I figured that that might be the answer.
If you are bent on having remote door locks just to have remote door locks You might have to fab a setup that in turn block the movement of the lever that the push button pushes on. As long as you rig something that keeps that lever from moving to actuate the latch the door can't be opened from the outside.
Old 01-21-2025, 01:24 PM   #17
SDRRACING
SDRRACING's Avatar
I just got off the phone with Trique Mfg and ordered the Altman latch. They told me they have a bracket coming that will attach to the Altman latch for mounting the power door lock actuators. How cool is that. Chris said it will be similar to the one they sell for the 67-72 trucks. https://triquemfg.com/products/keyle...hevy-gmc-truck
He is going to keep me posted and when I get the info I will share it with you.
