Old 01-04-2025, 08:41 PM   #1
msg
Glass setting tape recommendations?
Anyone had good results with any particular tape to set the door glass into? i have seen some that have cork as part of it and some that are just butyl I guess.
Progress thread for my 66
http://67-72chevytrucks.com/vboard/s...d.php?t=623848
msg is offline   Reply With Quote
Old 01-07-2025, 12:36 AM   #2
cwcarpenter98
cwcarpenter98's Avatar
Re: Glass setting tape recommendations?
I don't know what my local glass shop used, but the vent windows and side windows that I had them re-set haven't budged a bit since then
Christian Carpenter
Overdrive wiring here
1981 C10 - Penny 305, th350 --> Soon to be 350, Saginaw 4 speed
1995 Dodge Dakota Sport
Old 01-07-2025, 10:20 AM   #3
55-72 GM trucks
Active Member
fixing to try the tape classic parts of america sells for vents but my glass shop said to use black silicone so I did that on my 58 and it came out perfect on door and vents but if you ever wanted that glass out again I bet it would be nearly impossible to remove
55-72 GM trucks is offline   Reply With Quote
Old 01-07-2025, 11:43 AM   #4
rideblue00
rideblue00's Avatar
I used the glass setting tape from Classic Parts and it worked fine.
rideblue00 is offline   Reply With Quote
Old 01-07-2025, 03:23 PM   #5
GMCPaul
We carry the OE style glass setting tape in 3 thickness's
Part # 20077682 Glass Setting Tape
Professional weatherstrip glass setting tape. This is the material for installing vent window glass into metal frame and for installing door glass into the lower door sash metal channel that it rides on. This kit includes 2- 30" pieces that are 1" wide. Available in 3 different thickness, 1/16", 3/64", or 3/32" thick. Select thickness desired after adding to cart.
Manufactured by Precision
https://gmcpauls.com/60-66rubber_weather_strip.htm
Paul Jr @ GMCPauls
GMCPaul is offline   Reply With Quote
Old Yesterday, 04:39 PM   #6
forestb
forestb's Avatar
I bought some from one of the popular truck supply places and it was too thick. When I used it on the vent window it spread out the channel and caused the attachment pins to fall out. I would buy a couple of different thicknesses and see what works best.
Now that I think of it I wonder if that is why so many people have issues with the windows rolling up all the way and the channels getting stuck in the beltline fuzzies. If the tape is too wide then it will spread the channel apart and make it too wide to fit. Man I wish I thought of that a long time ago.
forestb is offline   Reply With Quote
Old Yesterday, 05:43 PM   #7
bigmoe
bigmoe's Avatar
It's a common problem for door windows not wanting to roll up because of the lower channel hitting the door whiskers. On my truck I pinched the top edges of that lower channel so the glass just fit in. Then I used windshield urethane caulk to fasten the glass in. If you go to a windshield shop before closing time you can often get them to give you a partial tube. My window channel still hits the whiskers but will easily bump past.
bigmoe is offline   Reply With Quote
Old Yesterday, 10:10 PM   #8
msg
Thanks for the replies, on the thickness I did see this precision video that explains how to tell what thickness you need. I had to order some new glass so Ill wait to measure everything once it gets here.
