Old 01-18-2025, 01:45 PM   #1
Dan-K
Axle shaft replacement
Finally installed a posi in my 72 C10 . The only issue is that both axle shafts are worn out at the seal . Where is the best source for replacements ?
Dan-K is offline   Reply With Quote
Old 01-18-2025, 02:51 PM   #2
Accelo
Accelo's Avatar
Re: Axle shaft replacement
An axle repair bearing exists that has seals as part of the bearing. (It is grease-lubed for life) The bearing doesn't rely on differential oil for lubrication.
I have used them, but they seem to have China tolerances. One was .008 larger on the OD than the ID of the axle tube. When forced into the hole, the axle bearing ID was reduced so much that the axle no longer fit.
I am unsure if my experience is the same as others. I would consider using them but only if I had the tools to measure the bearing and housing accuracy.
Maybe others have sources for replacement axles. Remember no all 67-72 axles are the same length and get measurements from your old ones.
Accelo is online now   Reply With Quote
Old 01-18-2025, 05:00 PM   #3
LS short box
I have used Moser axles over years and they have worked well for me.
Old 01-19-2025, 11:35 AM   #4
ZEKE68
ZEKE68's Avatar
Classic Industries sells Motive Gear branded axles for that truck.
1968 SWB Step Side, Big Block, 4L80E , Running!
ZEKE68 is offline   Reply With Quote
Old 01-19-2025, 11:49 AM   #5
LockDoc
The Older Generation
LockDoc's Avatar
I think you can still get repair sleeves for this. SKF used to have one they called speedi sleeve. It renewed the seal area on the axle.
https://www.ebay.com/sch/i.html?_nkw...fc6d4f0271ecb1
Leon
Old 01-19-2025, 03:23 PM   #6
'68OrangeSunshine
'68OrangeSunshine's Avatar
I had a differential rebuilt for my '67 K/10 Suburban in the mid-90s. The GM Eaton factory was on strike, and local dealers were flat out of OEM axles. I was told to call Moser. They cut me fresh axles for the same price as Stock. When I got them, I saw the hub diameter had less metal than the Chevy part. I called Moser. They said they were guaranteed for life. Still running that rearend under my '71 GMC Jimmy.
Old 01-22-2025, 04:02 PM   #7
D.PASSMORE
One of the First
D.PASSMORE's Avatar
This Place:
Tom's Differentials
DAVID PASSMORE
ST AUGUSTINE ,FL
ZIP 32084
'71 SWB K/10 CUSTOM DELUXE (Chili)
'72 BLAZER K/5 Muscle Truck (Mule)
'72 LWB K/20 CHEYENNE (Blackie)
D.PASSMORE is offline   Reply With Quote
