01-22-2025, 02:24 PM | #1 |
What size exhaust for a 454BBC
What size are you guys using especially with headers?......
want to keep the sound reasonable!
1970 2WD Blazer 454 1972 C-10 Extended Cab 350 SBC |
01-22-2025, 02:49 PM | #2 |
Re: What size exhaust for a 454BBC
No headers for me, went with factory cast manifolds with a clean 350 HP? (estimated) engine. 8.8-1 compression and a 268 comp cam. 2.5'' pipes out of the cast into a flowmaster Y then to a single 3'' through a dynomax muffler and out the back. I can light up the duals from a standing stop
01-22-2025, 05:12 PM | #3 | |
Similar here: 396, 9.5:1, comp xr270hr , hedman 68198 full length headers into 2.5 inch pipe with H-pipe near tranny tail section, through magnaflow muffs and straight out the back. No drone and relatively quiet inside but she barks pretty good from the rear. Oh and the torque available to my right foot is CRAZY! My 295x20 meats are turned via 700r4 w/~3000~ stall through a 3.73 posi. It will spin them from a standing start but with just a little brake to prevent rapid forward motion, I can light them up completely and paint crisp arcs of rubber on any dry road surface! -Kevin
67 C10 fleet fuel injected '70 402, 700r4, 3.73 posi 07 335 sport turbo 6sp 94 Trans Am GT LT1 6sp posi -- sold after 22yrs 99 540 sport V8 6sp -- sold 73 240z L24 4sp -- given to friend 68 C10 step 350/350 3.73 open -- sold |
01-22-2025, 05:54 PM | #4 |
20' Daredevil (Ret)
Ancient history, not really relevant I suppose..... My old (new when I bought it) '69 El Camino had an underrated 375HP 396 L78 engine. Chevy equipped it with dual 2.5" exhaust. I had a lot of fun with that car / truck.
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
01-22-2025, 07:32 PM | #5 |
At the body shop.
Dual 3 in h or x and 18in magna flows
" That didnt make it any newer " " Dont antique the equipment " |
01-22-2025, 11:13 PM | #6 |
Who Changed This?
I had a '68 Skylark that I put a 305 SBC engine in. I put a 2-1/2" exhaust system on it with headers and Flowmaster mufflers. WAY too loud. As for performance, I took it to a muffler shop and they installed 2-1/4" Flowmaster mufflers. I was short on time, as I traveled a lot for my job back then. Even with that puny 305 SBC, I could instantly see lower performance at WOT with the smaller muffler. I wish I had known about those Cadillac mufflers before that. At least the small diameter mufflers were quieter.
01-24-2025, 11:48 PM | #7 |
2” header and dual 2 1/2” exhaust should support 600 wheel horsepower. Personally, I think 3” exhaust is just way too loud and doesn’t add anything useful to a street vehicle.
01-25-2025, 09:29 AM | #8 |
My 72 C20 has a 511 with 600hp drives thru a T400 (2400rpm stall), Gear Vendors to a 4.10 Dana 60. I have Tri-Y headers to 3" pipes with "H" pipe at the tail end of transmission. Then thru Flowmasters out to rear. Great sound, not loud in the cab. I can listen to my radio or my cell with no issues. I also sound deadened/heat barrier the interior which helped a lot.
Darrell 1972 Cheyenne Super C20 (My Fun Drive) 2000 S10 Xtreme (My Drag Truck) |
Yesterday, 01:36 PM | #9 |
1 3/4 full length GM car headers
3" head pipes to a 3" 'H' pipe 3" intermediate pipes into 3" In/Out mufflers (DynoMax Super Turbo mufflers) 3" to 2.5" reduced tailpipes (transition @ back of cab) that angle down & out @ 45° by the bumper brackets @ the bed corners .030 OE '89 454 w/flat-tops Mild 'towing' cam Fairly quiet @ idle given it's a BBC w/3" exhaust but flows just fine once things get more active.
