Old 02-09-2025, 07:43 PM   #1
IT Cowboy
Active Member
IT Cowboy's Avatar
Location: Clarkdale, Arizona in a van down by the river
Squeak or whistle inside when starting or shutting down
It is coming from in side and it makes a distinct whistle type squeak in the same pattern. I think it is from the HVAC system and possibly the blend door closing, It is not a belt and it does it on startup and on shutdown
'72 C10 / 402
___________________________________________
Freedom isn't safe, it requires you to take responsibility for your own life, your own safety, and your own success. It carries with it the possibility of failure and the understanding that you're working without out a safety net. If you give the state the responsibility for any of these you also give up the freedom that accompanies the responsibility.
IT Cowboy is offline   Reply With Quote
Old Yesterday, 07:39 PM   #2
Rust_never_sleeps
Rust_never_sleeps's Avatar
Re: Squeak or whistle inside when starting or shutting down
vac lines to the flapper, and to the control panel
1970 C10 Custom longbed 350/350
Code:
            __
     ______|__]\____
....|___(o)_____(o)_]
Rust_never_sleeps is offline   Reply With Quote
