QA1 with 15's.....is it possible???
My son and I are getting back on the 67 and trying to figure out a few things
is it even possible to get the right spindles, hubs and brakes to make 15's work. I know Lucky did it back a while ago but we just don't know how to get there. Then there are all the steering components to put together..... And help and direction on this would be appreciated. |
Junior Member
![]() Join Date: Apr 2022
Re: QA1 with 15's.....is it possible???
Yes, I ran with 15x8 front, 15x10 rear rally’s on mine after qa1 upgrade. It’s the Wilwood brake front rear caliper upgrade I did months later that killed it.
I have 17”s now for clearance. |
The single best mod you will do to the truck is getting away from 15” rims IMO. If you have them and need to run them do it. But if you are buying wheels and tires move to the 17’s or 18’s now. I prefer the 17” size, but 18’s have better tire selection these days.
![]() Join Date: Jul 2000
Hate to hear that because many of us still like the old school look with 15" wheels. However, I just went to TireRack.com and found only 4 tires in size 255-70x15, which is one of the common sizes used on our trucks.
Mike 1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes. 1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold 1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it! 1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming. Retired as a factory automation products salesman. Worked part-time over the years for an engine builder and a classic car repair shop. Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then! |
![]() Join Date: Nov 2013
I put QA1 on my '67 and used 2" drop spindles and 28" diameter tires on 15" wheels. The result was that the lower arm was too low and would drag on the ground if the tire went off the edge of anything that was 3" lower.
I ended up putting the stock height spindles back on to gain enough clearance, and I still have to be careful not to let the front wheel drop off the shoulder of the road. I have about 4" clearance under the lower coil-over bracket. A larger wheel & tire would probably eliminate the issue. If I hadn't already had the wheels, I probably would have used 16" or 17"
1967 C10 Step side 1968 C10 Step side 1970 Chevrolet K/5 Blazer 1972 Chevrolet K/5 Blazer ............. ![]() |
So is it the overall tire height that's the issue? I can see where the ground clearance is low for sure, but whether it's a 15" or 17" isn't it the final total height of the rubber that sets the height? I am new to this, so I am sure I'm missing something.
Or is it getting the spindle and brake set up to fit in the 15 that's the issue.....or all of the above? |
ESC Thanks for your response on the qa1 issue. What spindle, brake and wheel set up did you have that worked and what made you go to the Wildwood brakes??
![]() Join Date: Feb 2016
You didn't specify which QA1 products you're planning on installing. It may make a difference.
Thanks to Bob and Jeanie and everyone else at Superior Performance for all their great help. ![]() RIP Bob Parks. 1967 Burban (the WMB),1988 S10 Blazer (the Stink10 II),1969 GTO (the Goat), 1970 Javelin, 1952 F2 Ford OHC six 4X4, 29 Model A, 72 Firebird (the DBP Bird). 85 Alfa Romeo If it breaks I didn't want it in the first place The WMB repair thread http://67-72chevytrucks.com/vboard/s...d.php?t=698377 |
#9 | |
Junior Member
This worked great, I ran rally’s, the ride was awesome. But I had a whining vibration noise from diff when going over 70 mph which led to me taking it to a shop for rebuild. They said drums were so bad they couldn’t get ‘em off. This is when I thought, now’s the time to upgrade to willwood. Not the big brake kit, just standard kit. Well they called cause the rear 15x10 rims were rubbing. Luckily I had a set of 17” intro wheels I’d bout 13 yrs ago. I’m rolling with these for now until I can afford to get new wheels I really like. |
#10 | |
On the wilwoods is this the system 12" they say will fit in 15's. What wheels were the 15x10's. Because there are truck ralleys, car ralleys, 67-68 truck ralleys.....and on and on. I really want to make some 15's work on this so that's for any help. |
We already put in the full coilovers and a arms with the stock cross member a few years ago and are just getting to move forward from that install.
Senior Moment
![]() Join Date: Mar 2002
My Truck with Full QA1 Suspension with 15” and 20” Wheels
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN 2013 GMC PU, Oldest Son 71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son 2017 Toyota SUV Daughters car 2018 Traverse , Wife’s Ride Pittsburg Ca 94565 |
