Old 03-08-2025, 02:01 AM   #1
62bagger
62bagger's Avatar
steering issue
I have a 65 front x member on my 62 that was installed when I bought the truck. I have 2" lowering springs ant 2" drop spindles. I had the truck aliened, and it feels like when turning the truck wants to dart in that direction. I went back and measured everything on the front end and noticed the pitman arm is 5" and the idler arm is 6". I have found a 5" idler arm from Moog and was wondering if this would correct the problem. Has anyone else has had this issue and how did you solve it. I am trying not to throw too many parts at this and cause a larger problem.
62bagger is offline   Reply With Quote
Old 03-08-2025, 01:26 PM   #2
bhap
bhap's Avatar
Re: steering issue
Arm length alone may not address the problem. I would think that mounting locations matter as much as length. To get a definite answer, you may need to establish a centerline and a perpendicular to see where pivot points are relative to each other. Take some measurements and get your protractor out.. Who said we'd never use geometry again?!?
bhap is offline   Reply With Quote
Old 03-09-2025, 01:16 AM   #3
62bagger
62bagger's Avatar
Re: steering issue
I will look into the pivot points. Thanks for the info.
Old 03-08-2025, 08:52 PM   #4
62 Barnfind
62 Barnfind's Avatar
Re: steering issue
Does it do it on full lock going slow or any time a road speed?
John Z
1962 Chevy C10 Stepside
62 Barnfind
My build tread: http://67-72chevytrucks.com/vboard/s...d.php?t=507513
62 Barnfind is offline   Reply With Quote
Old 03-09-2025, 01:20 AM   #5
62bagger
62bagger's Avatar
Post Re: steering issue
I notice it at normal driving conditions. At low speed it leaves tire marks on
ground and you hear the tires squealing.
Old 03-09-2025, 10:17 AM   #6
62 Barnfind
Re: steering issue
It’s not what I was thinking. I just did a 78 front swap in my 62. If I remember right I had both measurements of the Pittman and idler arm the same distance.
John Z
62 Barnfind
