Old 01-20-2004, 01:06 PM   #1
tomsC10R
tomsC10R's Avatar
Stock oval port heads
It's a 396. What kind of performance manifolds will work with the stock oval ports cylinder heads? I have no experience with big blocks but read that the stock oval port heads are much different than performance oval port heads which would probably mean they're much different than the intakes that are matched to the performance heads. Please tell me I don't have to buy new cylinder heads too. Oh yeah, I just bought a Holley MPFI (not brand new)
Thanks in advance!!
Tom
1968 C10 LWB. 402 BB, Holley MPI, 700R4. 4wheel Hydroboost Disk Brakes.
tomsC10R is offline   Reply With Quote
Old 01-20-2004, 02:17 PM   #2
JimKshortstep4x4
Talking
To my knowledge, the oval ports were the same until you got into the newer big blocks where they had very small ports. If your 396 is 72 back, I believe that you will be ok with any of the performance manifolds. (The differences of course would be between oval and rectangular ports).
jim
Old 01-21-2004, 03:03 AM   #3
tomsC10R
tomsC10R's Avatar
Thanks Jim.
Does everyone else agree?
Thanks again.
Tom
Old 01-21-2004, 04:06 AM   #4
Pont
I need another Barley Pop
Pont's Avatar
Yep, Jim is right on the money. I also have a 396 with closed-chamber oval port heads on it. Any performance manifold designed for oval port heads should work just fine (assuming it's not a tall deck 396 or 427).
67 Short Fleet 4x4
04 Honda CRF450R
89 Toyota 4-Runner
34 Ford 2 door sedan - Long term project
There is a very fine line between "hobby" and "mental illness"
Pont is offline   Reply With Quote
Old 01-21-2004, 11:23 AM   #5
tomsC10R
tomsC10R's Avatar
Thanks Pont,
That leads me to another question. Is there any easy way to tell if it's a tall deck? You can't tell just by looking can you? Are there certain casting numbers I should look for?
Thanks for all the help
Tom
Old 01-21-2004, 12:06 PM   #6
superchevy
Got big-block?
superchevy's Avatar
Check this link for big block casting numbers:
http://www.mortec.com/bbc.htm
superchevy is offline   Reply With Quote
Old 01-21-2004, 12:07 PM   #7
zyggy72
Can't kick the addiction!
There are certain casting numbers for tall deck blocks. The deck height of a std block is around 9.5 inches from center of the crankshaft to the deck and a tall deck block is about 10.2 inches from the center of the crankshaft to the deck.
Hope that helps.
zyggy72 is offline   Reply With Quote
Old 01-21-2004, 12:51 PM   #8
tomsC10R
tomsC10R's Avatar
Superchevy,
Thanks for the link!!
Just curious, but I didn't see any 396T (tall decks) listed on their page.
Not that I want it to be one
Tom
