Old 01-21-2004, 09:15 PM   #1
WB72
Before and After
WB72's Avatar
Ground strap
Is there supposed to be a ground strap from the bed to the frame?
I am having problems since I removed the bed, and rewired the rear harness. The problem is: once I have the side marker lights grounded, I have power to the bed, when I check with a test light from the frame to the bed. I know that is not right.
The harness was suspect #1 and it checked out OK. If I ground the marker light to the frame, it lights up.
What would you check?
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 01-21-2004, 09:23 PM   #2
WB72
Before and After
WB72's Avatar
When I Ground the bed to the frame, It works.
Can anyone tell me howlong of a strap that is required and it's location?
66,000 miles.
Alberta, CANADA
Old 01-21-2004, 09:29 PM   #3
Blue Beard
Blue Beard's Avatar
If in doubt, add one......can't hurt anything.........
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 01-21-2004, 09:36 PM   #4
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
I would think that the bolts holding the bed to the frame would be a adequate ground. Like he said above. Add one it won't hurt.
67Fleetsidedream is offline   Reply With Quote
Old 01-21-2004, 10:39 PM   #5
WB72
Before and After
WB72's Avatar
I think that I know what happened.
When I re-installed the bed, I put a rubber gasket inbetween the bed and frame to stop the squeeking that was there in the past. The bolts are not tightened to the frame yet so the box isn't really touching the frame and the bolts arent either.
I think that I will install one just to be safe.
Thanks for the help.
66,000 miles.
Alberta, CANADA
Old 01-21-2004, 10:59 PM   #6
ozarkhippie
I'm dealing with the same prob. I painted my frame and when I put the bed back on I forgot to clean a spot to bare metal. Now when I hit the brake all the lights come on. Rather than unbolting the frame again I just added a ground strap.
Buy Sale or Trade
71 3/4 4x4
72 1/2 ton cheyenne 4x4
ozarkhippie is offline   Reply With Quote
Old 01-21-2004, 11:06 PM   #7
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Had the same thing happen to my truck and when I added the ground strap it fixed all my problem's..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 01-22-2004, 01:02 AM   #8
WB72
Before and After
WB72's Avatar
I'm glad I'm not the only one with this problem.
Oh Ya, its FIXED.
66,000 miles.
Alberta, CANADA
Old 01-22-2004, 01:07 AM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Beds with wooden floors are more likely to have this problem, but there is nothing wrong with adding a ground strap...or two.
I go over board with ground straps and ground wires...but I never have ground problems either.
Old 01-22-2004, 01:11 AM   #10
gonebad2
Merciless Butcher
gonebad2's Avatar
Grounding Strap
Grounding problems can be the worst. I've had the same problems in the past. Summit sells these braided grounding straps. They're really cheap (around 5 bucks). And really do the trick.
Your Bought And Sold....I Got Your Soul!
gonebad2 is offline   Reply With Quote
Old 01-22-2004, 01:32 AM   #11
dinnut
dinnut's Avatar
wow, gonebad those look great! ill have to look into some of those
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 01-22-2004, 02:37 AM   #12
Hooter
My other Love
Hooter's Avatar
I have seen that Napa or Lordco if you are IN BC always has them
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
