![]() Join Date: Nov 2002
Generic Ignition Switch question
This switch is going on another project I'm working on . it has points distributor. Which wires do I hook up to start the vehicle? Do I need a direct hot lead from the batt. to the switch?
Thanks. |
Hope this helps if you need a schematic I can dig one up I did for a project of mine
Where did you find a switch like that........
Most of the ones I've seen that were universal had screw terminals.........
1970 Chev CST 2003 Harley Fatboy 1975 Chevrolet Step Van 1956 Chev Bel Air 1977 Blazer 2WD For Sale $3000.00 1978 Blazer 2WD For Sale $7000.00 1978 Silverado 2005 Monte Carlo |
![]() Join Date: Dec 2002
Switch looks like a replacement switch for a boat ...If brass comstruction; then probably for marine use....
'71 GMC;fleetside;PB/PS/AC/CC/402 Eng./Custom Paint/110,000act miles/3 fuel tanks(52gal). |
I work on forklifts, and that looks like an ign. switch from a Hyster forklift. Only thing, on a Hyster the center lug is for start, and the top lug is a ground. Check with a fork lift dealer, and they should be able to get you a connecter/plug with a short piece of wire attached to each terminal. Tell them it's for a Hyster "C" series, S40-60XL forklift. Good luck.
![]() ![]() ![]() LIFE AIN'T EASY WHEN YER FAT AND GREASY! GMC= Got More Class! ![]() ![]() |
I hooked up the wires like described in the above pic and no luck. I think I'll try OhioDan s description and see what happens.
now I have no spark coming from the coil, got juice to it(thru) probably bad coil, unless I'm missing something...? Last edited by 67sss; 01-24-2004 at 04:37 PM. |
