Old 01-24-2004, 02:48 PM   #1
ACES
Life is a gamble
ACES's Avatar
Ignition Key
I've got a '69 chevy swb, that I bought without an ignition key. Is there a # marked somewhere that I can take to a chevy dealership or a locksmith and have them make me a key?
-Art
ACES is offline   Reply With Quote
Old 01-24-2004, 03:01 PM   #2
71swb4x4
71swb4x4's Avatar
I think you may be able to take the switch/tumbler to the locksmith and they may be able to make a key for you. I am not positve but it may be worth a try.
Shawn
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 01-24-2004, 03:05 PM   #3
70short
Doesn't he need the key to remove the tumbler. If the tumbler is out just go to the auto parts store and buy A new one with keys there not expensive $15. That is what I did.
"72" Red CORVETTE 4-speed 350
"70" Chevy Short Bed early stages of resto.
Edel 600 cfm carb
Weiand Stealth Intake
HEI
shorty Headers
4/2 Drop
295 50R 15 TOYO on 10 inch wide corvette rally rims at all 4 corners.
"CHEVY RULES"
70short is offline   Reply With Quote
Old 01-24-2004, 03:49 PM   #4
ACES
Life is a gamble
ACES's Avatar
The tumbler is kinda my problem, I can't take it out without the key. Unless someone knows some kinda trick that I'm not aware of.
Old 01-24-2004, 04:32 PM   #5
67sss
67sss's Avatar
ign
pop off the shiny face off the switch,break it off, and then it'll come out. don't scratch the dash.buy a new one from someone here.
67sss is offline   Reply With Quote
Old 01-24-2004, 04:54 PM   #6
Dan72cst
Dan72cst's Avatar
IF and I mean IF your door locks are the match to your ingition, then you can take the door lock to a locksmith. I'm pretty sure they have a number stamped on the lock.
Marysville, WA (Dan72cst@hotmail.com)
72 4wd Blazer CST 350/350
72 4wd Chevy LWB 350/350
68 2wd Chevy LWB 327/400
Dan72cst is offline   Reply With Quote
Old 01-24-2004, 11:09 PM   #7
ACES
Life is a gamble
ACES's Avatar
Unfortunately, the door locks don't match the ignition.
I like 67sss's idea of snapping off the shiny face, but I'm not quite sure how to do it without scratching the heck out of the dash.
1970 Orange CST C-10 w/350, posi, Longbed
The torpid artist seeks inspiration at any cost, by virtue or by vice, by friend or by fiend, by prayer or by wine.
-- Ralph Waldo Emerson
Old 01-25-2004, 01:53 AM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I am not trying to sound liek a smart alleck here, but if you never had a key, how do you know the same key won't fit the doors?
They were siongle key vehicles from the factory.
Old 01-25-2004, 01:55 AM   #9
71swb4x4
71swb4x4's Avatar
Maybe he has the key for the door, and it doesn't work in the ignition.
Old 01-25-2004, 03:26 AM   #10
ACES
Life is a gamble
ACES's Avatar
Well, the reason that I believe that the door locks and the ignition don't match is because the doors are not original and are each from different trucks. I suppose it is possible that one of the PO's transferred the locks from the original doors to the replacement.
Old 01-25-2004, 10:40 AM   #11
Blue Beard
Blue Beard's Avatar
The right hand door lock on some of these had a code that would allow a locksmith to cut a key from the code.
GM use to use only 1500 key combinations.
I've had keys that started many numerous cars when they became worn down enough.
the correct way to remove the cylinder involves using a paper clip in the little hole by the keyway and depressing a pin inside there.......at the same time turning the tumbler counter clockwise which releases the cylinder.
The GM uses wafer tumblers inside with a sidebar lock.
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 01-25-2004, 12:42 PM   #12
Longhorn Man
OK, my mistake, I didn't even think of doors being swapped.
When i bought my GMC it didn't have a key either. It took a little bit of messing around with it, bit eventually I got a screwdriver in it (With a 5 pound hammer) and then was able to remove it all and replace the whole ignition assembly.
To get it home I just unplugged the ignition switch and hooked the harness into my spare ignition switch and let it dangle under the dash. Had to drive it like that for a month. Kinda hard to explain to the cops when they pull you over and they see a screwdriver in the ignition switch and another ignition switch dangling from under the dash.
Old 01-25-2004, 12:48 PM   #13
da-burb
"Ochre Ogre"
da-burb's Avatar
Here is how to replace the ignition using force. You will need a new cylinder and switch, cost is about $25. Start by prying off the stainless cap on the cylinder. Then uncrew the bezel until it is tight against the lock cylinder. At this point the will be unscrewed and out of the bezel, the only thing keeping it in is the cylinder. Take 1 hammer and 1 appropriate sized punch and pop it out the back of the dash. I have done it this way several times with out any damage to the dash or the bezel.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
