Old 01-26-2004, 08:24 AM   #1
TIMSPEED
TIMSPEED's Avatar
Ever wonder the difference between BT's 6" Flip vs DJM's 5" Flip?
I've always wondered why the BellTech's are rated for 6", while the DJM is only 5"...same parts, looks like..hmm..anyone know?
BellTech's:
DJM's:
Hmmmmmm....
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 01-26-2004, 12:52 PM   #2
N2TRUX
Happy to be here
N2TRUX's Avatar
Look at the bump stops on the BellTech kit they are taller. Yeah that's what it is, the bumpstops are taller...
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-26-2004, 02:36 PM   #3
low 84
low 84's Avatar
those are some skimpy looking bell tech notches............only 6 bolts..............
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 01-26-2004, 06:45 PM   #4
1FaastC10
1FaastC10's Avatar
Western Chassis stuff looks way beefier than either of those.
1FaastC10 is offline   Reply With Quote
Old 01-26-2004, 06:51 PM   #5
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Could it be related to the variaton in the amount of drop you get based on the thickness of the spring pack? My understanding is that you get more drop if you have more leaves. Maybe one vendor states the maximum you can get and the other states the minimum.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 01-26-2004, 08:41 PM   #6
TIMSPEED
TIMSPEED's Avatar
Are you talking about the C-Notch portion of the Flip Kit? If so, I'm not debating that here, I'm debating the difference in the actual FLIP KIT and what makes it 5" or 6"...
See Them Here
Old 01-26-2004, 08:47 PM   #7
TIMSPEED
TIMSPEED's Avatar
DJM = $90
WC = $80
Hmmmmmm....So I will have to start endorsing the WC Flip Kit...since it's $10 cheaper!
See Them Here
Old 01-26-2004, 09:01 PM   #8
shavedchevy
shavedchevy's Avatar
Is wester chassis the same as chassis tech. That what I get up north here at a shop and they claim it's the best..and for all I know it is. I don't know about if I got the full six inches out of my drop though.
Dennis
shavedchevy is offline   Reply With Quote
Old 01-26-2004, 09:09 PM   #9
shavedchevy
pre drop...
Dennis
Old 01-26-2004, 09:10 PM   #10
shavedchevy
post drop... 4/6
Dennis
Old 01-26-2004, 09:53 PM   #11
low 84
low 84's Avatar
the only way belltech could make there flip lower than any other flip would be in the design of the saddles if the saddle were designed taller, as in the "U" shaped portion moved up further that would drop it more. it would be like adding a 1 inch drop block on a flipped axle
'05 1500 Crew Cab
RIP
Old 01-26-2004, 09:54 PM   #12
TIMSPEED
TIMSPEED's Avatar
Originally posted by shavedchevy
Is western chassis the same as chassis tech. That what I get up north here at a shop and they claim it's the best.
Chassis Tech is basically shAIM in disguise...
See Them Here
Old 01-26-2004, 10:24 PM   #13
SCOTI
SCOTI's Avatar
The difference in drop is going to be the difference in the thickness of the spring pack. They advertise them as different rates based on 'typical' installations & don't guarantee the 'exact' amount of drop because of variances in different vehicles.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-26-2004, 10:33 PM   #14
BaggedC10
Under construction!
BaggedC10's Avatar
No, the two companies are not the same. Chassis Tech (AIM Industries, Truckin' Suspension, etc.) has a poor quality and service reputation. Stay far away from their components.
2001 Silverado bagged on 22's. *Sold*
BaggedC10 is offline   Reply With Quote
Old 01-27-2004, 01:12 AM   #15
1FaastC10
1FaastC10's Avatar
i have seen shAIM flip kits, and owned their shackles, hangers, and drop spindles. i have also owned a Western Chassis setup including flip kit, c-notch, shackles, and spindles. the shAIM parts were visibly cheaper (casting flash on the spindles, welds werent as good of quality) than the WC stuff. there is NO way that these two products are "the same".
Old 01-27-2004, 01:21 AM   #16
bigblock73
yeller
bigblock73's Avatar
i have seen shAIM flip kits, and owned theyr shackles, hangers, and drop spindles. i have also owned a Western Chassis setup including flip kit, c-notch, shackles, and spindles. the shAIM parts were visibly cheaper (casting flash on the spindles, welds werent as good of quality) than the WC stuff. there is NO way that these two products are "the same".
theyr???
bigblock73 is offline   Reply With Quote
Old 01-27-2004, 03:24 AM   #17
1FaastC10
1FaastC10's Avatar
i fixed it douchebag, are ya happy?
hey Josh, is there any way we can get a spellcheck feature added to the board?
Old 01-27-2004, 11:44 AM   #18
Slonaker
Slonaker's Avatar
I think that's what I said...
Slonaker
Stock '01 Silverado
Old 01-27-2004, 02:19 PM   #19
8t5Silverado
Mudslides 'r my specialty
8t5Silverado's Avatar
$80 or $90?
I think PSC has them for $60...
Always on the lookout for old cars and parts...(20s, 30s, 40s, 50s, 60s, etc.)
http://www.cardomain.com/memberpage/500339
8t5Silverado is offline   Reply With Quote
Old 01-27-2004, 03:38 PM   #20
BaggedC10
Under construction!
BaggedC10's Avatar
$10 difference, big deal.
I've had both WC and DJM flip kits for my previous truck. I was more impressed w/ DJM's product. The finished product looked much better---Powdercoat is durable, the holes were drilled straight, and the edges were nicely finished. The WC kit was on the "rough" side. I observed this in both flip kits I purchased from them.
