Old 01-26-2004, 04:12 PM   #1
Brently
Rear end problems? yikes
I have a popping coming from the rear end - it is a posi rear end in my 72 swb - just bought the truck and it appears to be the one that came in it - it says this is what it is in the glove box lid - i haven't checked the gears - the popping only occurs when i turn - it is like the axle stops turning when i turn a curve - it pops loud and jumps - but again only when i turn - this confuses me - i know nothing about rear ends so can someone help please? Brent
Brently is offline   Reply With Quote
Old 01-26-2004, 04:26 PM   #2
67chevemall
67chevemall's Avatar
Maybe low oil but sounds like a rebuild Gears are cracking together in the diffy gears!
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 01-26-2004, 04:28 PM   #3
stelth2002
Young Gun wth Fast Inline
stelth2002's Avatar
Posis can have that characteristic, but i would check it out for sure
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!!
stelth2002 is offline   Reply With Quote
Old 01-26-2004, 09:32 PM   #4
1972C10
1972C10's Avatar
My 85 did that when the clutches went out it was locked into full time 2WD
1972C10 is offline   Reply With Quote
Old 01-26-2004, 09:47 PM   #5
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Sound's like the clutch's are going out....I had a 66 that did the same theing untill it was a 1 wheel peel..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 01-26-2004, 10:35 PM   #6
bumpster
Junior Member
Check/change the fluid before you tear it down. If the fluid gets too old or wrong type put in, the clutches won,t release as they should. It would probably feel like you are running over a brick with whichever tire is on the inside of a hard slow turn. good luck
72 C10 10 yr.daily driver
68 C10 18 yr.money pit
72 Nova all original
99 H.D. Heritage[sanity check]
71 VW topless bug[summer fun]
"When I have the money, I don't have the time ; when I have the time, I don't have the money.
bumpster is offline   Reply With Quote
Old 01-26-2004, 10:50 PM   #7
corn
Yea, change the gear oil first & make sure you use posi lube. GM also makes an additive for posi units that comes in a little bottle & I think its made of whale blubber if I remember right, quiets them right down...corn
corn is offline   Reply With Quote
