Old 01-26-2004, 06:36 PM   #1
WB72
Before and After
WB72's Avatar
Sawzall
I am debating on getting a sawzall. Will they cut through rivets and frames?
Or are they just good for wood?
Not Grandpa's C-20 anymore...
383 Stroker 425HP, 485Ft/Lbs
Lowered 3.5" Front / 5" Rear
66,000 miles.
Alberta, CANADA
WB72 is offline   Reply With Quote
Old 01-26-2004, 06:38 PM   #2
1974StepSide
Play it Loud...
1974StepSide's Avatar
With the right blade, they will cut through damn near anything
Big Moe
1974 Cheyenne Super Stepside, 350/400, Hooker Headers, Flowmaster Mufflers... Needs new doors, fenders, hood, and paint.
1952 Chevy Pickup waiting to be brought back home!
1974StepSide is offline   Reply With Quote
Old 01-26-2004, 06:39 PM   #3
gr8scott51
gr8scott51's Avatar
Use a grinder for rivets. Sawzall is good for sheetmetal. Plasma cutter or torch for frame, heavier metal.
at least this is my experience, scott
Silence is golden, duct tape is silver. - Scott
gr8scott51 is offline   Reply With Quote
Old 01-26-2004, 06:58 PM   #4
Scrubby
Check out GMTrucks.org
With a metal cutting blade in a sawzall, you can use it to cut sheetmetal to frames. It is one of the most versitile tools I have.
Scrubby is offline   Reply With Quote
Old 01-26-2004, 07:01 PM   #5
krue
Designated A-hole!
krue's Avatar
That's why it's called a SAWZ---ALL!
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 01-26-2004, 07:46 PM   #6
Gene
Gene's Avatar
I used mine to hack my dash to fit a new cd player cause I aint skeered:p
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 01-26-2004, 07:48 PM   #7
rodnok1
rodnok1's Avatar
Buy good blades for cutting steel, the cheap one's are OK for thin metal. Rivets don't cut with blades. You could cut the steel easier than the rivets. Grinder and drills for rivets. The good one's have a quick change for blade for no tools needed. Mine has a setting that also drives the blade forward for aggressive wood cutting. I have a Porter Cable 737 Tiger saw...had it for few years..awesome tool.
64 Panel Rebuild Pics
Clutch Replacement and Borg Warner T10 Trans Rebuild
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
rodnok1 is offline   Reply With Quote
Old 01-26-2004, 07:49 PM   #8
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I've cut anything with mine. Crossmembers, frames, rivets sheetmetal......
Dozens of Volkswagen bugs have fell victim to my SawzAll. You can cut one into small enough pieces to pile it in the bed of a pickup in about 10 minutes.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 01-26-2004, 08:07 PM   #9
boraxman
Keepin an eye out
boraxman's Avatar
I love my Sawzall along with my Visegrips Moderen day miracal tools
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 01-26-2004, 08:10 PM   #10
superchevy
Got big-block?
superchevy's Avatar
I c-notched the frame of my '93 with a sawzall.
Cut like butter.
SC
superchevy is offline   Reply With Quote
Old 01-26-2004, 08:32 PM   #11
CPNEJR
CPNEJR's Avatar
Lets ask you guessed it Bozall:p
Yeah they cut through just about anything I know
(Only) Member of the CPNE Fan Club Aint that the truth
67 C-10 350 with 3-speed tranny and 308 gears swb step
82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine)
72 Chevy K20 Suburban (future project)
70 Chevy K20 now 68 GMC K2500
2003 Chevy 2500hd ccsb 4X4 (daily driver)
CPNEJR is offline   Reply With Quote
