Old 01-28-2004, 09:42 PM   #1
72BLAZERDUDE
72BLAZERDUDE's Avatar
Upper control arm bushings
I have a upper control arm bushing that is bad. Is it possible to take it out without taking the control arm off. It is starting to make noise. Im just trying to do a quick fix until I can finish buying all of the stuff for a complete front end rebuild. Maybe 2 months at the most. Hoping the control arm is okay.
72 2wd 307/AT/AC/TILT WHEEL
78 JIMMY HIGH SIERRA
72BLAZERDUDE is offline   Reply With Quote
Old 01-28-2004, 11:06 PM   #2
walker
walker's Avatar
I don't think so. It is not that hard to do upper control arms though. Jack the truck up and put on stands. Remove the wheel. Place floor jack under the spring tower and take up the slack in the spring. You can then remove the nuts holding the upper control arm in place. Then you can turn the control out and replace the bushings.
Good luck.
Andy,Phx AZ
'67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...)
"23 C-Cab-sold
'48 Ford 8N tractor(still working)
'67 Scout(Now on the road)
'70 MG B.-sold
walker is offline   Reply With Quote
Old 01-29-2004, 04:41 AM   #3
Sweet72
Sweet72's Avatar
You may be able to remove only the upper control arm shaft and bushings without splitting the upper ball joint. Support the front crossmember with jackstands, remove wheel, and then use a floor jack or bottle jack under lower control arm to hold the spring in place. Remove Bushings and then nuts holding UCA cross-shaft to frame. Remove and tape together and label caster/camber shims for reinstallatin in original positions. Observe torque specs for installation of new bushings, as it is easy to strip the threaded holes in the UCA. Best of luck.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
