Old 01-29-2004, 12:52 AM   #1
krazy_texan
krazy_texan's Avatar
manual trans?
what all is needed to put a manual trans in my truck, i know of the obvious trans and driveshaft, what else is needed.
Krazy Texan
My Trucks are made with Wrenches not Chop Sticks
1967 GMC 3/4 ton "Johnny Cash"
1990 v1500 suburban
1967 Ford f100 Swb 4x4 "green bean"
GOD BLESS JESUS, JOHN WAYNE, AND THE ALAMO
krazy_texan is offline   Reply With Quote
Old 01-29-2004, 12:57 AM   #2
stelth2002
Young Gun wth Fast Inline
stelth2002's Avatar
crossmember, and carrier bearing setup if your running a long box. clutch, and flywheel, unless you had a manul before.
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!!
stelth2002 is offline   Reply With Quote
Old 01-29-2004, 01:06 AM   #3
CG
BlahBlahBlah
too bad a 4x4 has diff mounts id trade you all my 4sp stuff for your automatic. i hate shifting
Old 01-29-2004, 01:19 AM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Lets not forget the clutch pedal and Z bar assembly allong with everything that connects it together.
Old 01-29-2004, 01:52 AM   #5
walker
walker's Avatar
Don't know if I saw a shifter in there, better throw one of them in too
Andy,Phx AZ
'67 C-10 (Ahhh, done at last. Well there is that disk front end I want to put in and...)
"23 C-Cab-sold
'48 Ford 8N tractor(still working)
'67 Scout(Now on the road)
'70 MG B.-sold
walker is offline   Reply With Quote
Old 01-29-2004, 02:05 AM   #6
Hooter
My other Love
Hooter's Avatar
and dont forget the little bearing that goes in the hole in the back of the crank
Castlegar B.C.The great white North (Canada Eh!)
Hooter_5@hotmail.com
First generation Monte Carlo club
pictures of my life
Hooter is offline   Reply With Quote
Old 01-29-2004, 12:48 PM   #7
krazy_texan
you mean the pilot bearing
Krazy Texan
1990 v1500 suburban
Old 01-29-2004, 06:03 PM   #8
1972C10
1972C10's Avatar
I may have most of that stuff that you wil be needing i know i have the plate that mounts on the engine will the ball the clutch pedal and rod the crossover tube that goes from the engine to the frame
let me know if you need this stuff id get rid of it cheap sincei dont need it.
1972C10 is offline   Reply With Quote
Old 01-29-2004, 07:08 PM   #9
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
krazy, I have all of the linkage and pedal that I pulled out of my 70 a couple of months ago.
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 01-29-2004, 07:28 PM   #10
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
Pressure plate and bolts
flywheel and bolts
clutch disk 10 spline
bell housing and bolts
the z bar and the braket that holds that on.
Is it going to be a column shift or a floor shift?
shift bar ( the one that goes on the throw out bearing)
throw out bearing
pilot bushing.
shift linkage on the tranny
slip yoke
This is all that I can think of neighbor.
67Fleetsidedream is offline   Reply With Quote
