Old 01-29-2004, 03:30 PM   #1
6T9GMC
6T9GMC's Avatar
Question Help Please!
Where should my amp guage be reading? I changed the two fuses by the firewall and guage barely moves. The needle is just around the second mark from the bottom on the left side of the guage. Does this sound right and should it move when the truck is running?
THANKS!
6T9GMC is offline   Reply With Quote
Old 01-29-2004, 03:34 PM   #2
SWEET7T
Try spinnin 4 rear tars
SWEET7T's Avatar
Your truck wont charge much, if you don't drain the battery much. Under most conditions, mine barely moves to the charge side. If your truck isn't running and you flip on your blower motor and lights to make a good drain, it should show a discharge. Doing that, mine moves about a 1/4 to the left of center.
As for when my truck is running. Mine jiggles around a bit.
SWEET7T
1970 C10, 2wd, LB, 307/TH350/3.08. PS, PB
SWEET7T is offline   Reply With Quote
Old 01-29-2004, 05:44 PM   #3
6T9GMC
6T9GMC's Avatar
Should it pretty much be in the middle when truck is running with out anything turned on? (headlights, blower motor, etc)
thanks
Old 01-29-2004, 06:17 PM   #4
Wootdog
Wootdog's Avatar
Yes
it should be right in the middle,
Kerry
1967 C10
Got it back after three years
Boy I sure missed Peppy
1969 Chevelle
1990 IROC Z Convertible
2002 Silverado LT
Wootdog is offline   Reply With Quote
