Old 01-30-2004, 07:19 PM   #1
72SWB4X4
Florida Key's Member
72SWB4X4's Avatar
locating the temp guage wire?
does anyone have a wiring harness diagram or can lend assistance?
Craig Wood
1972 SWB Chevy Cheyenne 4X4
Restored stock except 454 (481 cu. in. now)
most options Available
pictures of my truck http://myoldtruck.com/gallery/browse...500&userid=528
Come to florida and visit www.Paradisewatersports.com
72SWB4X4 is offline   Reply With Quote
Old 01-30-2004, 08:54 PM   #2
72SWB4X4
72SWB4X4's Avatar
update
ok i have done some testing of the sender wire and the temp guage and the wiring harness and the voltage at the guage cluster
sender wire has no ohm drop from the pin on guage plug to the sender on the motor...
temp guage reads 54.2 ohms resitance across the two side terminals
voltage at the guage on the printed circuit reads 12.8 volts on one side and 7.4 volts on the other
Craig Wood
Old 01-30-2004, 09:26 PM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
when you ground the wire, what does the guage do?
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 01-31-2004, 09:53 AM   #4
72SWB4X4
72SWB4X4's Avatar
grounding wire
tell which wire you are referring to and ill try it
Craig Wood
Old 01-31-2004, 10:11 AM   #5
Tx Firefighter
Is there a green wire that goes to the temperature sending unit?
Old 02-02-2004, 10:13 PM   #6
72SWB4X4
72SWB4X4's Avatar
green wire
yes there is a dark green wire running from the guage to the sending unit
Craig Wood
Old 02-03-2004, 12:10 AM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Ground that green wire, if the guage tachs out, then everything from that wire to the guage is working. (assuming it goes to full ledt when not grounded)
