Old 01-31-2004, 03:26 PM   #1
nu2-72
need info on K5
Just brought in a rolling frame. It is supposed to be a 72 K5.
Just wanting to verify some things.
Glovebox said 1HO510 3:73 rear. PITT ?
Is this a p-trac?
It is also disc brake and 6 lug with leaf springs.
Just trying to find out what all is there.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
2004 Duramax Silverado 4x4
2006 Duramax Crew cab 4x4
2010 Harley Ultra Limited
2011 Harley Street Glide
nu2-72 is offline   Reply With Quote
Old 01-31-2004, 03:32 PM   #2
autolabor
Posi Tracton if I'm not mistaken. I took my rearend apart and it's just four sets of springs sandwiched between two diskes that apply pressure to the side spyder gears. I've been told its similar to the old "lincoln Lockers", but it's effective. I assume the disks are in the front and drum in rear?
autolabor
1971 Chevrolet K-5 Blazer;
Yamaha Road Star warrior all stock.
autolabor is offline   Reply With Quote
Old 01-31-2004, 03:48 PM   #3
nu2-72
Yes, disc front and drum rear.
It is about 6 degrees out and warmer in here. So I will ask questions now from the warmth of my chair and check it out on a warmer day.
Has steering box, front sway bar, 4 very nice 31-10.50-15 tires, steering stabilizer and little more.
Going to see what I can use and unload the rest. Very nice frame but I do not think it is a 72. The guy thought it was a 79 with all the 72 stuff under it.
The double wall top was next to it and the last of the Blazer tub was there. Pretty fair buckets. No AC,radio or much else. Just the glovebox door.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
Old 01-31-2004, 09:50 PM   #4
Rod
Not sure what the pitt stands for , but the H05 option was athe 373 gears.
You gotta see a G80 option for posi.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 01-31-2004, 11:04 PM   #5
OLDCHEV4X4
OLDCHEV4X4's Avatar
I dont think 72's came with a sway bar.
Don't quote me on that.
Randy
72 k/10 short wideside
72 k/5 Blazer
72 K/5 Blazer - obstacle course racer
72 custom/10 8' bed
70 K/5 Blazer
67 C-30 GMC Flat bed
86 GMC K2500 Plow Truck
85 GMC K3500
84 M1008
85 M1008
77 G30 Motor Home
72 Sears 12hp Tractor
Glenmoore, Pennsylvania
OLDCHEV4X4 is offline   Reply With Quote
Old 02-01-2004, 02:59 AM   #6
nu2-72
Blazers did come with sway bar.
The glovebox showed rear diff. 3:73 PITT
1HO510 is the code on the door.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
Old 02-01-2004, 10:52 AM   #7
Blazer1970
Blazer1970's Avatar
'69 - '72 4 wheel drive Blazers did not come with a sway bar. Neither did any other GM 4X4 until '73.
Blazer1970 is offline   Reply With Quote
Old 02-01-2004, 10:55 AM   #8
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
I second the no sway bar's.....
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 02-01-2004, 12:30 PM   #9
nu2-72
Guess I was thinking of something else on the sway bars. Thought I have seen some. And my GM book shows #6274060 as Ser 10-30, Blazer. Must be 2wd only then. That would confirm that this is a later frame. But it all fits so nicely. I think I will see if it will fit my 4X4.
72 3/4 4x4 350 4spd
72 3/4 4x4 350 auto
Old 02-01-2004, 01:01 PM   #10
teeitup
Just like to part out trucks!!
teeitup's Avatar
Kevin, Rob and Wes told me no sway bars on our years. Wes can tell you what you have to do to make it fit right, sound like a good purchase, not much snow here yet.
67 Chev swb stepside 4x4 283 4 speed SOLD
72 blazer 4x4 4 speed Cheyenne
72 GMC swb 4x4 fleet 4 speed, original paint
1958 Cameo (one of 1405 built, it was my dads)
2020 chevy Apex 4x4 crew cab
1969 Z28 with the 302
1980 chevy swb 4x4
1964 chevell Malibu SS
1976 K20, sold new originally out of my dads chevy dealership
Members that I've met, over 200 probably closer to 300 in the 12 years I've been on this site, everyone I met "It was a pleasure"
teeitup is offline   Reply With Quote
