Old 02-06-2004, 03:14 PM   #1
47Firetruck
Question 74-70 axle swap
I've got a 70 C-10 with the factor 12 bolt rear and 6 lugs. I also have a 74 1/2 ton parts truck with a 12 bolt rear and 5 lugs. Can I swap the 74 axles into the 70 12 bolt housing? Or should I just weld on new mounts and swap the whole diff? Thanks for the help!!
47Firetruck is offline   Reply With Quote
Old 02-06-2004, 03:51 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
You may be able to do it, might not. All depends on your 70. Some were wide, some were not. All you have to do is pop off the cover and pull the C-clip and give it a shot.
Old 02-06-2004, 06:15 PM   #3
kaycee
kaycee's Avatar
HMMMMM
My 70 was a narrow 1 so I had to make a spacer for each side.I have been told they made a wider 1 sometime in 70,thus making it a direct swap.My 69 & 70 r the same size 55 1/2" from backing plate to plate if using the newer axles you might need to use the drums allso I had to. The spacer I used was a homemade 3/4" on each side between the housing & backing plate I used 2) 3/4" steel plates so I could keep it some what sealed.I was lucky enough to use plasma cutter,drill press,4"grinder so it was not hard at all
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 02-07-2004, 02:02 AM   #4
47Firetruck
Thanks for the replys guys! When I get back in the states I'll have to see what happens, hopefuly it will work.
Old 02-07-2004, 10:17 AM   #5
Blue Beard
Blue Beard's Avatar
Isn't the 74 a leaf spring setup...?
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 02-07-2004, 11:37 AM   #6
47Firetruck
Blue Beard
74 is a leaf spring setup, but you can buy or torch off the mounts from the 70 and weld onto the 74 housing. I'd just by the new saddles myself. I've found them on the net.
Old 02-07-2004, 12:47 PM   #7
70short/step
70short/step's Avatar
So the spring mounts on a 73 and newer leaf rear end are different than the 67-72 leaf rear ends??
70short/step
70short/step is offline   Reply With Quote
Old 02-07-2004, 08:58 PM   #8
Longhorn Man
With no papers here, I have to say I remember some one saying the spring perches are not the same width, nor same distance.
I may well be wrong on this, I have never paid much attention to the leaf spring 1/2 ton stuff.
