Old 02-07-2004, 08:21 PM   #1
MrGoodpliers
MrGoodpliers's Avatar
Question Ball joint interchange?
I have a '70 GMC 3/4 ton driver and a '72 3/4 ton heap. Want to rob the disc brakes off the '72. I know that the taper on '67-70 ball joints and tie rod ends is different from '71-72 for 1/2 ton trucks. Are they different on 3/4s as well?
We made Oklahoma a little after 3, Randy & his brother Bob & my old GMC...
MrGoodpliers is offline   Reply With Quote
Old 02-07-2004, 08:26 PM   #2
racedvl
racedvl's Avatar
Yes, they are diffrent.
racedvl is offline   Reply With Quote
Old 02-07-2004, 08:32 PM   #3
MrGoodpliers
Phooey.
Old 02-07-2004, 08:49 PM   #4
smitty62
smitty62's Avatar
Phooey?..............................PHOOEY?
How dare you!!!
Stepsides look like real trucks!
Smitty
smitty62 is offline   Reply With Quote
Old 02-08-2004, 11:29 AM   #5
MrGoodpliers
Some more questions
Okay, I have a '72 1/2 ton frontend laying around (at my folks, so I can't look at it and measure). Are the control arms, shafts and ball joint diameters the same for 1/2-3/4? Meaning can I rebuild my 1/2 ton control arms to 3/4 ton specs? Can I use 1/2 to shafts or will I need a complete shaft kit? Will 3/4 ton ball joints fit 1/2 ton control arms? Thanks.
Old 02-08-2004, 12:03 PM   #6
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
If you rob the 1/2 ton disk's your gonna have a 5 lug up front and 3/4 ton in back ???? Or do you have a 1/2 ton rear end already in back? If you already have 5 lug in the rear just swap put the 3/4 ton font to the half ton front end..
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 02-08-2004, 02:47 PM   #7
MrGoodpliers
No, I want to keep it a 3/4 ton and swap the discs from the '72 3/4. I was just thinking about rebuilding the frontend while I was at it, and wondering if I could rebuild the 1/2 ton control arms/shafts with 3/4 parts. The 1/2 ton stuff is already loose, so I could do that stuff and then just rob the spindles from the 3/4.
Old 02-09-2004, 12:50 PM   #8
MrGoodpliers
ttt
