Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > Info Center > Review Board > Vendor Reviews
Old 02-10-2004, 11:27 AM   #1
SS55
Thumbs up Amps to Volts conversion
Many years ago I had Bill Russell of Clock-Doc convert my factory Amp gauge to a Volt gauge. It works great, the center mark is calibrated to 12 volts so as long as I have normal charging voltage, the needle swings to the right, about 1/4" of movement.
I called Bill yesterday to see if was still doing that kind of work and he welcomes all board members and said he would acid etch the gauge as part of the conversion for free. If the gauge needs silk screening, there would be additional charges.
He can modify your printed circuit so that the newly converted gauge will run from the keyed Ign-on, same as the fuel gauge.
If you send a gauge to him, send the plate that holds the Amp and Temp gauges as well. The plate needs an extra hole drilled for the gauge conversion.
So, if you want to maintain factory looks but have a Voltmeter rather than an Ammeter, then contact Bill.
His contact info:
Bill Russell
Clock-Doc
10 Main Street
Monteagle, TN 37356
(931) 924-8888
Be wary of the light at the end of the tunnel....It might be a gorilla holding a flashlight!
71 Blazer, ex-4WD...Bought it that way
55 GMC
55 Belair 2dr HT
67 El Camino
SS55 is offline   Reply With Quote
Old 02-15-2004, 02:24 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Interesting, what does he charge for this service?
Old 02-17-2004, 07:02 PM   #3
SS55
Price for conversion is $95.00
I think he said plus $45 for silk screening, if needed or wanted.
55 GMC
55 Belair 2dr HT
67 El Camino
