Garage Queen Material
widest tire on 8" rim?
how wide of a tire can i run on an 8" rim?
I don't know how safe it is but I had a friend run 305's on his 8" rim. Be we mostly all ran 295's. I've got 275's. I heard that theh wider the tire it is the easier it will pop of the rim if you've got any lateral pressures on the truck, like turning corners or pull $hit hooks on gravel roads and such... or so I've heard.
Dennis |
www.73-87chevytrucks.com
![]() Join Date: Dec 1999
Well, it is recommended not to go over 10", but GM put 275/60/15 (as do I) on their 454SS rims. So you should be ok. Any more and you are going to be getting irregular tire wear.
Chris Lucas 1973 Chevy C-10 1978 GMC Jimmy (2WD) - SOLD 1987 R10 twin turbo LS 1991 R3500 SRW CrewCab 1985 K5 diesel swapped project 1989 K5 2WD conversion w/ Vette susp Project Captkaos Customs 73-87chevytrucks.com |
305 will fit..barely. Better get a 10" wide rim. 305 (and 295s) on an 8 inch rim make for balloon like tires. If you do it get the ones with the 60 aspect ratio, the taller side walls will give some more leeway and a better contact patch.
yep, i wouldn't go any wider than what i think you already have, 275/60/15. any wider and it will look dumb and you will probly get less traction than with the 275's.
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works '05 1500 Crew Cab RIP '84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker '80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's |
You get what you pay for
275's work fine, but if you want the longest lasting, best tread wear, 255's work best.
Mike 1985 Chevy C-10 |
well, i already have 2 tires, 275/50/17's
so for the front i'll get 255/50/17's |
Killin' Time
how about this, kinda the opposite, can I run 275 60's on my 10" wide 15" rims??
NEED CORVETTE 1972 GMC C20 350, SM465, HEI Dynomax headers and 2.5" duals |
#9 | |
#10 | |
Formerly yellow72custom
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
I have 275/60/R15s on my 10"wide 15" rims! Doesn't look ailly to me
http://www.crossfire.homeip.net/twinnie/trucklg7.jpg |
You can fit a 295 on an 8" wide wheel without a problem.
But I wouldnt go any larger then 295 on an 8" wide wheel. I have 295's on my 8" up front and 295's on the 10" out back.
* AVOID: LOPER'S PERMORANCE / LOPERSPEED.COM OF PHOENIX, AZ & COTTMAN TRANSMISSION * |
