Old 02-11-2004, 02:58 PM   #1
90blzr
LOTS OF PARTS...tires, wheels, lift kits..all must go!
Cleaning up again and need to move some of this stuff. I dont wanna move it to the new storage. All prices are plus shipping. Pics available upon request.
Also have many parts for a 1999-2002 Chevy 1/2. drivetrain, bed, front clip (might be an 03 clip, but if intersted I can find out), interior, axles, etc.
***TIRES/WHEELS***
** (3) 38.5x16x15 Swamper SXs good for spares, have little tread, $30 each
** (4) 38x15.50x15 Ground Hawg II Radials. 95% plus tread. GREAT shape. set of four $1000.
** (1) 35x12.50x15 Swamper Radial SSR. Used for spare, little tread, mounted on 6 lug steel wheel. $50
** (1)36x12.50x16 Swamper Radial, spare, little tread, $40
** (4) Stock blazer wheels with center caps and beauty rings set of four $100
** (4) 33x13.50x16 Swamper LTBs with about 75%+ tread $300
** (4) 33x14.50x15 Mickey Thompson Baja Belted about 15% $50 takes them all.
** (2) 35x12.50x16 BFG All Terrain KO's with about 90% tread $200 for the pair!
***MISC***
** HURST SHIFTER - handle and boot, great shape $25
** SUBURBAN INTERIOR TRIM - trim pieces (blue) from an 88 suburban $50
** Borla Stainless Muffler 19"x9.5" $50
** FOG LIGHTS - about 2"x4" or so $20/Pair
** Running boards off of a K5 blazer. Diamond plate, good shape. $50/pair
** Nerf bars for 2000-ish Ford F-150 ext. cab shortbed. Chrome, good shape with scratch on bottom. $150/pair.
** Flowmaster Exhaust and Airaid Intake for 1999-2003 chevy 1/2 4.8, 5.3, 6.0. $250 for both
** Roll pan 1999-2002 chevy truck. Sir Michaels, brand new w/license plate box still in box $150 shipped.
** Roll pan 88-99 brand new, with licens plate box. $150 shipped.
** Tail light fillers for a 88-98 chevy truck. Sir Michaels, brand new still in box. $30 shipped
** F150 stock upper and lower control arms, complete $100/set
** 1999 chevy S-10 bench seat, gray cloth, like brand new. $100
** 1999 chevy S-10 stock lenses (in grill/parking light or turn signal, cant remember ) $25/pair
** 1984 chevy S-10 rear end. 3.42 gears, good shape, complete drum to drum $150
***DRIVETRAIN***
** Vortec engine, 5.3, 4L60E, NP246 includes ALL WIRING, ALL COMPUTERS, everything you will need is there. All still hooked up and not butchered at all. Everything has under 40K on it. Still like new! Out off 2001 chevy
** 14bff, shafts, carrier, 3.73 gears, housing, hubs, drumbs,
etc.
** Rear disc brake axle from newer chevy. Great shape, like new, complete from caliper to caliper. 3.73's. open. $600
** Dana 60 front 4.56 ring, pinion, and 4.56 and up carrier. All BRAND NEW, never used, still in the original boxes. $250
** Th350 automatic, 4wd, ran great when pulled. long shaft.
$100
** 700R4/241 combo out of 1990 K5. Tranny shifts/run fine, NP241 fine, just need to replace seal on t-case. R4 shift hard in first at times. Make reasonable offer.
** Axles from 1990 K5, 10bolts, complete, front has warn premium hubs and the 30 spline shafts, 4.10 gears, open.
Rear is also 10 bolt with 4.10 gears and Auburn limited slip. All in good shape.
$600/pair.
* REAR sway bar from a 14bff $75
***SUSPENSION***
** 4" Trailmaste lift kit for a 88-98 Chevy 1/2T truck. GREAT shape. complete with shocks, etc. Also have aluminum skid plate. $1000 obo.
** 6" Superlift kit, 3" body lift, 36" TLS Radials on Weld Super Single II's. For 1999-2003 chevy. COMPLETE and in greats shape. Dual shocks, etc. EVERYTHING is there. $2300
** 3" drop kit came from 2000 F-150, belltech. coils and hangers. good shape. $100
** 4" lift kit for 1990 K5. 4" front Rancho springs, rear blocks, steering arm,. $150.
90blzr is offline   Reply With Quote
