Old 02-12-2004, 11:22 PM   #1
81chevy
what is best way to get more traction
I have a 81 chevy 2wd 12 bolt rear with aurburn posi trac with 342 gears
I just put in a new 400 hp 350 and can't stop spinning what can i do with the shocks , springs , or traction bars to help
thanks
81chevy is offline   Reply With Quote
Old 02-13-2004, 12:52 AM   #2
NeCrOmAnCeR
NeCrOmAnCeR's Avatar
Sounds sweet. Keep in mind trucks are lite in the rear and it sounds like you already have tried to get the power to the ground. Put on some wider tires, softer compound, or maby some "sandbags" in the back. Or you could just put a brick UNDER the loud pedal so it won't go down so far. Ya Right!!!
NeCrOmAnCeR is offline   Reply With Quote
Old 02-13-2004, 04:06 PM   #3
rodnok1
rodnok1's Avatar
softer springs in the rear, drag shocks up front to let the front end rise to transfer weight to rear, bigger and softer tires. Or quit poping the clutch at 6k rpm...
64 Panel Rebuild Pics
Clutch Replacement and Borg Warner T10 Trans Rebuild
64 Panel 1/2 Ton
350cubes/400hp
BorgWarner t-10
3:73 Auburn Posi
rodnok1 is offline   Reply With Quote
Old 02-13-2004, 05:41 PM   #4
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
http://www.calvertracing.com/
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 02-16-2004, 09:34 PM   #5
clipity
Big hands Big feet ohwell
clipity's Avatar
Buy a Suburban, lots of weight over the rear tires.
I only drive as fast as I can see!!!
89 Suburban 4x4
49 Willys flatbed 4x4
87 Banshee
88 Katana 1100
clipity is offline   Reply With Quote
Old 02-19-2004, 06:08 AM   #6
TIMSPEED
TIMSPEED's Avatar
I aswell recommend CalTrac's. If you can't get it to hook on a 28x12 15" Soft Compound tire, then definately get a set of CalTrac's. :yesnod:
EDIT: These tires should do the trick M/T Sportsman's
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 02-20-2004, 12:31 AM   #7
81chevy
what are caltracs how do they work the web site is under construction thanks
Old 02-21-2004, 02:18 AM   #8
DennyB
Led Sled! Discs R 4 ME!
DennyB's Avatar
Click on the information link, More info there
Here is just a piece...
Tremendous benefits can be realized when the CALTRACS traction bar system is installed on a leaf spring suspended automobile. CALTRACS traction bars were developed to achieve specific goals to improve high power traction while staying within hard set NHRA parameters.
Each of the two assemblies needed is comprised of three basic components:
1. Front Pivot
2. Force Transfer Link
3. Rear Mount
The combination of these components changes the pushing point on the car by redirecting the turning action (spring wrap-up) of the rear axle through the Force Transfer Link into the Front Pivot. The Front Pivot Spring Stop Bolt resists this turning motion and also controls the bending of the leaf spring at its thinnest section. The push into the Front Pivot helps the cars weight shift towards the rear of the car because of a new directed angle of force toward the front of the vehicle. (The "Instant Center" moves farther forward). This is where the system emulates a Four link system. The pinion angle is also maintained. (See illustration)
"Never ride faster than your Angel can fly"
I.M.O.M,W,J&C
Patriot Guard Rider
DennyB is offline   Reply With Quote
