Old 02-14-2004, 05:38 PM   #1
rn2fine
rn2fine's Avatar
New GM 383 Partial Engine
FYI - I was surfing around the GM Performance Parts website and discovered that GM is now selling new 383 short blocks. They have been selling the long blocks for several years now but I think the 383 availability as a short block is new this year (???). Anyways, looks interesting. Includes quite a bit of stuff. See list below. Here is the info that I cut and pasted from the site.
12498332 Engine Parital 383ci
What a great starting point to build your own hot rod 383 engine. The only major items you will need to complete your engine are cam, lifters, cylinder heads, and manifold.
This 383 ci partial engine is used on all 383 crate engines.
The partial engine includes the following items:
P/N 88959106 - Block, 383 stroker after machining - Q/P 1
P/N 12489436 - Crankshaft, 383 stroker - Q/P 1
P/N 10120990 - Bearing standard front & intermediate - Q/P 4
P/N 10120993 - Bearing standard rear - Q/P 1
P/N 12523924 - Bearing standard connecting rod - Q/P 8
P/N 14088784 - Sprocket, crankshaft - Q/P 1
P/N 14088765 - Flexplate assembly - Q/P 1
P/N 12497624 - Rod, connecting single 383 - Q/P 8
P/N 12489437 - Piston & pin assembly standard 383 - Q/P 8
P/N 12522848 - Ring set standard 383 stroker - Q/P 8
P/N 12555283 - Pump assembly, oil - Q/P 1
P/N 12550042 - Pump assembly (screen) - Q/P 1
P/N 3764552 - Shaft, oil pump drive - Q/P 1
P/N 12557558 - Pan assembly, oil - Q/P 1
P/N 10108676 - Gasket, oil pan - Q/P 1
P/N 12562818 - Cover, front timing (plastic)- Q/P 1
P/N 12498008 - Balancer - Q/P 1
The partial engine does not include camshaft, lifters, timing chain or cam sprocket. The oil pan is loosely assembled on the block. So it can be disassembled without destroying the pan gasket.
72 C10 Burb 350 700R4
70 C20 LWB 350 Crate TH400
68 Chevelle
rn2fine is offline   Reply With Quote
Old 02-14-2004, 05:44 PM   #2
68 Suburban
68 Suburban's Avatar
Did they post a price?
Just sitting here contemplating contemplation.
68 Suburban is offline   Reply With Quote
Old 02-14-2004, 05:48 PM   #3
rn2fine
rn2fine's Avatar
# 3150 at Sallee Chevrolet (checked on web).
Hey 68, we should get together some time since you are so close. I am going into Goodyear today with the kids. Are you near Litchfield Road or Dysart.
Jeff
68 Chevelle
Old 02-15-2004, 04:00 AM   #4
jimfulco
http://sdpc2000.com/cart.asp?action=...=514&pid=81632
jimfulco is offline   Reply With Quote
Old 02-15-2004, 10:02 AM   #5
Blue Beard
Blue Beard's Avatar
How about some links for the sites you checked out....?
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 02-15-2004, 03:02 PM   #6
Ackattack
Ackattack's Avatar
I talked to the manager at a GMPP counter, and he told me they were coming out with a zz383 soon!
Ackattack is offline   Reply With Quote
Old 02-15-2004, 08:41 PM   #7
SCOTI
SCOTI's Avatar
Yep. I've heard about them but yet to see one in the flesh until today @ the Dallas Autorama. It's the 383 w/the HOT cam & the 'FastBurn' alum heads. No intake, flexplate, w.pump, or ignition..... & no price listed.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 02-16-2004, 03:22 AM   #8
rn2fine
rn2fine's Avatar
The AUtocenter in TX is already selling them that way (Fast Burn & Hot Cam). I think that they are probably taking the GMPP 383 crate motor and making the mods themselves. Here is the web site:
http://www.goautocenter.com/383_small_blk.htm
Someone else asked for the GMPP web site address for the short block 383. Here it is (also includes all GMPP blocks and partial engines):
http://www.gmgoodwrench.com/gmgoodwr...on=ep#12498332
Jeff
68 Chevelle
