GO VOLS!
body mounts
Has anyone tried to replace the body mounts (bushing and hardware) with the tub and radiator support still on the frame? The one pictured is one of the better ones, the others are all dry rotted. TIA.
http://1972blazer.shutterfly.com/<= blazer build pics It's called golf because all the other four letter words were taken. It's easier to ask for forgiveness than for permission. |
I did the mounts on my pickup, just undo all the bolts then jack up the body near each mount. Put your ebrake on just in case you knock the transmission out of gear while lifting the body and check peroidically to make sure that the different body panels arent rubbing into each other, ie. front of doors hitting the front fenders.
GO VOLS!
Thanks. I'm gonna do a body off rebuild but i want to see exactly how the body sits with good mounts and check for any sag.
mount bushings
IF YOU NEED A SET I HAVE TWO SETS ONE NEW ONE USED $80.00 FOR THE NEW AND $50.00 FOR THE USED. MADE BY ENERGY SUSPENSION
slogo, do have any rubber ones or just the poly?
BOTH ARE POLY
GO VOLS!
Slogo, If you still have them when I sell my seats and 4 point harness I'll drive up a get them.
orangeuavol, Sounds good just let me know when your ready.
orangeuavol, here's part number
GO VOLS!
Slogo, PM or e-mail my Dad (jhow66) you're contact info and when you can be reached.
