Old 02-16-2004, 02:36 PM   #1
67chevemall
67chevemall's Avatar
Welding exhaust pipe?
Any one know of a good site to read up on welding exhaust?
I want to customize a exhaust but have never welded pipe!
What settings do you set the mig to?
Or should I use torches?
Any info?
Help!
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 02-16-2004, 03:18 PM   #2
roadking
took mine to car x , they dont know how to weld either. im like you i should learn to weld again.
71 C10 SWB
BLACK AND WHITE
350 CRATE TH350
ENJOY LIFE
roadking is offline   Reply With Quote
Old 02-16-2004, 03:22 PM   #3
crazy4chevs
crazy4chevs's Avatar
just make shure that the pipe dosnt have a coating on it. its a pain to weld (unless you grind it off)
70 chev c10 swb fleet
72 grill, sb 400, 2/4 drop.
68 chev c10 swb fleet
Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C
Classic GM Truck Club of Washington
crazy4chevs is offline   Reply With Quote
Old 02-16-2004, 03:58 PM   #4
mocwon
Keep On Truckin'
mocwon's Avatar
Clean good and mig weld. I wouldn't use torches if you have a mig welder. Plus, if you have to do any welding with the pipe installed, which you likely will, torches are way too dangerous. All welder models are different so it's impossible to state a setting. Practice on new scrap pipe so you can sneak up on the proper adjustment for heat and wire feed.
Just Passin' Thru
Some projects are like herding cats; others are like putting out fires; this one was like herding cats on fire.....
mocwon is offline   Reply With Quote
Old 02-16-2004, 04:13 PM   #5
Southpa
Southpa's Avatar
If possible, set up some sort of supporting jig so you can keep the two pieces in line and can turn them. Your best (and easiest) welds come from the "flat" position. If you are welding thick walled pipe you could bevel the mating edges slightly to get good penetration. Align the two pieces about 1/32" apart and tack them together with 3 or 4 evenly spaced tacks. If you want to run continuous beads between the tacks you could have an assistant slowly turn the pieces while you weld. I would suggest filling by tacking evenly all around if by yourself. This will keep the heat down and prevent any blowthru but you still need enough heat to get good weld penetration. I would suggest running your mig between 70 and 90 amps for exhaust pipe.
If you have any left over scrap pieces you might want to practice joining them, recut, join again etc. until you feel comfortable with your technique, settings, position etc.
LOL, I can remember repairing old exhaust pipe with a torch and a coat hanger for filler metal. Lots of mini-explosions from the rust and coat hanger material is made of the most impure concoction of metals you could imagine.
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 02-16-2004, 04:15 PM   #6
stllookn
Saving 1 truck at a time!
stllookn's Avatar
It's really easy to do once you have removed the bed and cab! A truick lift makes it much easier too. I have done mine by lots of cutting, tacking then removing the pipes to weld them. They will move all over if the ends are not cut pefectly square. They can still pull when welded. If you are patient you can do a decent job...it just takes time.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 02-16-2004, 04:51 PM   #7
67Fleetsidedream
Wiseass secured himself a BAN
67Fleetsidedream's Avatar
Bolt everything up and tack it all together. Then remove and put a continues weld all the way around. Too bad you don't have a TIG welder. You could make some really pretty welds around the joint. Take your time.
67Fleetsidedream is offline   Reply With Quote
Old 02-16-2004, 05:57 PM   #8
Beefcake
A guy here at work said he used to heat up galvanized fence post and bend them in between two rims. Im not sure if this works, but sounds feasible.
72 GMC Camper Special 2500.
currently has 350/350/14 bolt. 383 and 400 tranny is in the works.
Beefcake is offline   Reply With Quote
Old 02-16-2004, 06:13 PM   #9
FirstGen
Just Don't Stop!
FirstGen's Avatar
if you use galvanized definatly don't breathe it!
1968 C10 build in process
TT LSA/6L90e/9"
FirstGen is offline   Reply With Quote
Old 02-16-2004, 11:52 PM   #10
Blue Beard
Blue Beard's Avatar
Most of the shops in this area use a wire feed now....a few still use a torch...
1970 Chev CST
2003 Harley Fatboy
1975 Chevrolet Step Van
1956 Chev Bel Air
1977 Blazer 2WD For Sale $3000.00
1978 Blazer 2WD For Sale $7000.00
1978 Silverado
2005 Monte Carlo
Blue Beard is offline   Reply With Quote
Old 02-17-2004, 06:32 PM   #11
gregsplace
gregsplace's Avatar
If all you have is a torch set up., DONT use coat hangers, junk metal as stated above. Use baler wire, soft and works good, specially on old exhaust,
67 3/4 4x4 402,a/t,flat bed
98 GMC Sierra swb daily driver
87 burb parting out.
68 1/2 chevy, 350/350, 71 gmc frame, kid's beater
69 1ton 396-4sp, dump
69 swb stepside 396/400th current frameup
67 swb 454/400th rebuilding now, oldest boy just rolled it
99,HD, Road King Classic
Colwich Ks
gregsplace is offline   Reply With Quote
Old 06-23-2004, 10:03 AM   #12
67chevemall
Thanks guys
I think I'll let speedy muffer do it
As it is already on the truck!
With clamps
Get them to weld the clamps up tight
Old 08-28-2012, 12:04 AM   #13
GuyO
GuyO's Avatar
Re: Welding exhaust pipe?
Old thread I know, but Harbor Freight sells a 110 volt 90 amp wire feeder for $109.00. Perfect for exhaust, filling trim holes, patch panels, etc. Get the special wire cutters and splatter spray to keep the nozzle clean. Good little project welder.
GuyO is offline   Reply With Quote
Old 08-28-2012, 01:14 AM   #14
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
I would much rather weld patch panels and fill holes with a gas mig and solid wire. Way less spaltter and cleanup grinding.
Gary
'cuz chicks dig scars...
I would never rebuild a 305.
Old 08-28-2012, 09:33 PM   #15
pritch
pritch's Avatar
Although it's been years since I've tried to do any of it, I was always a better welder with a torch than an arc, for stuff like light-gage pipe. I should hook up my welding tip someday and see if I still got it.
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
