Old 02-17-2004, 09:49 PM   #1
76bonanza
76bonanza's Avatar
Msd ?
Looking ito buying a msd hei probillit dist. it says"The PN 8365 is designed to replace GM HEI Distributors that use a 4-Pin ignition module." Is there anyway to tell with out looking in my distributer if Mine is a 4-pin?
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 02-17-2004, 09:54 PM   #2
76bonanza
76bonanza's Avatar
Also that Dist. is ready to run right?
1968 c10
lowered 3" 4"
Old 02-17-2004, 10:41 PM   #3
apstguy
LED King
apstguy's Avatar
Yours is a four pin. The 5 pin (which they don't make) is ESC which is installed on all the 80's 305s. They have 3 pins too ,but I *think* it was for cars.
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 02-17-2004, 10:54 PM   #4
1FaastC10
1FaastC10's Avatar
i've never seen a 3 pin module before.
1FaastC10 is offline   Reply With Quote
Old 02-17-2004, 11:17 PM   #5
CRRoy71
You can run it straight out of the box, but I would recommend setting the advance springs and weights to your application. The dist will come with an assortment of springs and stuff, and directions. It may be set up just how you need it right out of the box though.
Chris
'92 ext. cab s/b 4.3L "Sparky"
'04 crew cab 2500 4x4 6.0L
CRRoy71 is offline   Reply With Quote
Old 02-17-2004, 11:24 PM   #6
apstguy
LED King
apstguy's Avatar
MSD has it in their catalog that there are 3 pin modules & that MSD doesn't have modules for this application - I've never seen one either.
Tyler
2016 Chevy Spark EV
Gone: 2008 VW R32
Old 02-18-2004, 12:48 AM   #7
ocbaud
Garage Queen Material
good choice. i'll be getting model 8361
ocbaud is offline   Reply With Quote
Old 02-18-2004, 10:17 AM   #8
DCRANER
Msd
MSD is a very good choice, but setting up the correct springs is important.
I just ordered an 8361 and that one and most other MSD's will come with two silver springs, and these are too stiff. You will not get full advance until 4000 RPM's +, way too late. The stock advance bushing stop (blue) is set for about 21 degrees.
Most 350 small blocks want 32 to 36 degrees total advance and that should come in at about 3000 to 3400 RPM's.
I am planning on starting with 11 degrees initial timing, going to two light blue springs which should give me full mechanical advance at about 3000 RPM's, and leaving the stock blue advance stop bushing, so I should wind up with a total advance of about 32 degrees at 3000 RPM's. And with 11 degrees initial timing I may also disconnect the vac. advance.
Doug
86 GMC SWB, DK. BLUE, ZZ430,TH400, 4.11'S, HEADMAN CERAMIC HEADERS, WELD BILLETS, BFG 275 / 60 / 15, 325 / 50 / 15 DRAG RADIALS, FIBERGLASS COWL HOOD, B&M SHIFTER. MSD, MARCH PULLEYS / ALT. / PWR. STEER PUMP, BECOOL RAD., BILLET GRILL & GRANT WHEEL.
DCRANER is offline   Reply With Quote
