Old 02-18-2004, 12:32 AM   #1
milner
milner's Avatar
Driveshaft
I was wondering if anyone would know or has done this. Is it possible to convert the two piece driveshaft to a one piece? I have a 72 2 wheel drive long box. Thanks in advance.
milner is offline   Reply With Quote
Old 02-18-2004, 12:40 AM   #2
bad 71 chevy
bad 71 chevy's Avatar
i have one on my truck i have not had any probs yet i had it costom made i was blowing out carrier bearing out about 1 every 2-3 months i think that it cost me some where between 200$ to 350 something like that hope this helps
71 Chevy C/10 lwb 350
5 speed nv3500
3.73 rear end
2.5" Front Drop and 4" in the back
Edelbrock perfomer rpm manifold
Edelbrock 600 cfm carb
Headmen headers
bad 71 chevy is offline   Reply With Quote
Old 02-18-2004, 12:42 AM   #3
milner
milner's Avatar
Yes,thank you. That is exactly why I would like to convert to a one piece. Thinking about swapping to a much healthier motor and didn't want to change the hanger bearing everytime I decided to use it.
Old 02-18-2004, 01:04 AM   #4
71Rat
ran out of money
71Rat's Avatar
bad 71 chevy: did you have to grind out the crossmember the driveshaft goes though to make it work? plus is your truck lowered or anyting?
Sorry to kinda hijack this thread but i was also wondering the same thing.
sorry again
thanks
Rat
Modify everything, leave nothing alone!~
71Rat is offline   Reply With Quote
Old 02-18-2004, 01:06 AM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
You can run 12's on a stock 2 pc set up. If your C-bearing is going out often, then there is something else wrong.
Old 02-18-2004, 01:07 AM   #6
bad 71 chevy
it is not lowered but does have week springs but yes i did have to have a welding shop cut and then weld in a new pice kinda like a drive shaft loop i have had no probs with anthing but i might have some when i do get it lowered but thats while form now
5 speed nv3500
3.73 rear end
Headmen headers
Old 02-18-2004, 01:21 AM   #7
71Rat
ran out of money
71Rat's Avatar
bad 71 chevy: do you have any pics of your crossmember?
i am hoping to run low 12's maybe 11's when truck is done... or even faster if i can.... but NHRA might not allow the 2 piece shaft for running that quick... it doesnt specify in the rule book so i have to call the local guy for me
Rat
Old 02-18-2004, 01:24 AM   #8
bad 71 chevy
i dont have a digi cam but i might be able to find a buddy of mine to take some pics i will post them hear if i can get some
5 speed nv3500
3.73 rear end
Headmen headers
Old 02-18-2004, 08:24 AM   #9
Longhorn Man
71Rat, I know runnin high 12's with a slick, a stock 2 pc was fine.
Old 02-18-2004, 10:05 AM   #10
milner
milner's Avatar
71Rat:not a prob on the hijackin thing...good question I wish I had thought of it.
bad71: I would also like to see pics if you can get some
Old 02-18-2004, 11:59 AM   #11
slam33
slam33's Avatar
I use to blow out carrier bearing all the time until I did my last install a differant way. I hung the carrier to the frame, left it loose to move, and did the rear u-joint first, then I tightened down the carrier. Seems that I was pulling the bearing back when I did the u-joint last and that would wear out the bearing donut.
71 LWB 350/350still working on it but it's going tp be sweet. www.geocities.com/stevemau/slam33page.html
" TARGET=_blank>http://www.geocities.com/stevemau/slam33page.html?1004806705410
</A>
slam33 is offline   Reply With Quote
