Old 02-18-2004, 03:18 PM   #1
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Steering shaft
Anyone know the spline sizes into the box or into the column or length? I would like to get a custom shaft made since I can't find an aftermarket one.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest.
2wdBlazer is offline   Reply With Quote
Old 02-18-2004, 03:27 PM   #2
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Oh, This is for a 4x4 as well.
Old 02-18-2004, 04:38 PM   #3
bouncytruck
SKINNY TIRES RULE!
bouncytruck's Avatar
Do you have cross over? If not, you should consider it before getting the sterring shaft made, especiall with the big meats you got on that thing.
bouncytruck 1972 K5
The Hauler 1994 K1500 Suburban
The Daily2010 Kia Soul
Wife's Ride2014 Fiat 500L
bouncytruck is offline   Reply With Quote
Old 02-18-2004, 06:39 PM   #4
2wdBlazer
The Blazer King
2wdBlazer's Avatar
No Crossover and don't intend to. It drives very, very straight already and really doen't have bump steer at all. My stock shaft is on it's last leg though. I have contacted Borgeson Corp and they need those measurements to make a custom shaft. They are very good strength and quality.
Anyone know of a company that sells shafts that will fit? I don't wanna take my daily driver apart to make measurements.
Old 02-18-2004, 09:40 PM   #5
blazer1971
Take it to Bob's machine shop over the bridge in Ruskin.
blazer1971 is offline   Reply With Quote
Old 02-20-2004, 10:55 AM   #6
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Anyone got A parts truck laying around for measurements?
Old 02-20-2004, 04:16 PM   #7
69k5
i have a 72 4x4 k 20 . what exact measure ments do you need?
69k5
69k5 is offline   Reply With Quote
Old 02-20-2004, 05:50 PM   #8
2wdBlazer
The Blazer King
2wdBlazer's Avatar
Length from box to column where it bolts up. Spline count on each side where it bolts in.
Old 02-20-2004, 09:03 PM   #9
69k5
ill see what i can do tonight and let you know tommorrow.
Old 02-21-2004, 02:53 PM   #10
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
You might give Flaming River a try.
http://www.flaming-river.com/enter.htm
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 02-21-2004, 07:37 PM   #11
69k5
69k5
19 7/8 from the ltip of the clamp where it joins the column. that is with about an 1/8 between the clamp and the round black part of the column. and is measured from the lower part in the rag joint?(4 bolts that hold the shaft to the box. ) 36 splines on the column end. i couldnt get the other end off to count but i imagine its the same.
69k5
Old 02-22-2004, 02:11 PM   #12
earl87gta
earl87gta's Avatar
Thier is a guy over at CK5.com that sells them for $75 I think If you go to the salvage yard you can get one out of a van and cut the center section down the vans use 2 ujoints like the flaing river joints and a vibraion dampner My joint with the dampner for my truck came from a van and Im using a flaiming river at the coulume and I only have abought $85 in the hole thing would have had alot less if I would have known abought the van thing.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 02-24-2004, 04:48 PM   #13
1971 2wd
Cut out the middle section [-------------]
Drill out thr area where the shaft is 3/4" and put in a chunck of 3/4" chrome rod [=======] BLING BLING
Very trick and you lose the Collapsable junk. Done it on my 2wd, very easy to do..
72 blazer, 71 2wd short bed, 67 nova
Too many damn toys!!
1971 2wd is offline   Reply With Quote
Old 03-23-2004, 06:57 PM   #14
earnhardt221
i have the stock shaft from a 4x4 if u need one (cheap)
E-mail: earnhardt221@aol.com
earnhardt221 is offline   Reply With Quote
