02-18-2004, 11:22 PM | #1 |
Future Owner
starter question
i went from a 307 3 on the tree to a 350 auto. The flexplate i installed is 168 tooth. I should be able to use the old starter correct???
Its not the end result that counts most...its the journey along the way that's most rewarding My truck doesn't leak, it just marks it's territory |
02-19-2004, 12:47 AM | #2 |
If the starter is from your manual transmission you cant. THere are different starters for manual and auto's. Manuals are bolted to the bellhousing, and autos are bolted to the block. You will need to buy you a Block mounted starter.
1971 LWB Chevy C-10 350/350 3:42 eaton |
02-19-2004, 01:25 AM | #3 |
My other Love
the flywheels should be the same, I think 400 smallblocks had different flywheels, someone correct me if I am wrong
Castlegar B.C.The great white North (Canada Eh!) Hooter_5@hotmail.com First generation Monte Carlo club pictures of my life |
02-19-2004, 01:48 AM | #4 |
Autos don't use flywheels-----
Stepsides look like real trucks! Smitty |
02-19-2004, 01:51 AM | #5 |
My other Love
well duh, I meant flexplate
02-19-2004, 01:51 AM | #6 |
Formerly yellow72custom
If i'm not mistaken, starters for auto trannies have an allumium nosecone, while manual tranny starters have a cast iron nosecone.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
02-19-2004, 09:38 AM | #7 |
If you are using a 168 tooth flex plate you will want to get a block mounted starter with the diagonal mounting holes. It is possible to have aluminum or cast iron noses on starters. If there ever were a distinction between the two noses it is not evident today.
Jim |
