Old 02-25-2004, 02:23 AM   #1
Perchjerker
Beer Power!!!!!!!!!!
Perchjerker's Avatar
Machine Shops
Anybody here know of or reccomend any machine shops here in East Texas? My 307 still runs good but is using some oil and I think it is time to freshen it up a bit.
Bye the way, how many times can you rebuild an entire engine? For example, if you were not going to bore it and have it balanced each time it is built. I have heard that engines are only good for one rebuild then the block is trash. Is that true?
Rather be fishin'
Perchjerker is offline   Reply With Quote
Old 02-25-2004, 05:30 AM   #2
jimfulco
Haven't used them yet, but I've heard good things from several sources about Thompson Performance in Henderson.
jimfulco is offline   Reply With Quote
Old 02-25-2004, 11:50 AM   #3
botboy
If you aren't boring out the cylinder bores or bearing journals the block will be fine. After enough running you will have to bore out the cylinder bores or you will have piston slap and excessive oil consumption with standard sized pistons. Higher nickel content blocks are more resilent to wear.
botboy is offline   Reply With Quote
Old 02-25-2004, 12:30 PM   #4
/<eystroke
/<eystroke's Avatar
Bill Spence in Sherman is good. I've had many people recommend him. He
rebuilt a 350 in a '89 I had a few years ago. If you just want a basic
engine you should look into getting a longblock. I just replaced my
engine with a remanufactured engine from Jasper engines. Couldn't beat
the price for an engine with a 3yr warrenty delivered to your door in
two days.
'69 C/10 Short Wide
350/400/AC/Tilt/Tach
/<eystroke is offline   Reply With Quote
Old 02-25-2004, 12:51 PM   #5
70ChevyLongbed
Howzit?!?
70ChevyLongbed's Avatar
Re: Machine Shops
I'm glad to hear that another 307 is getting freshened up instead of being switched out -- granted I'll get a 350 when my 307 has seen it's last days too, but it's still a good motor.
As for the engine only being good for one rebuild, I thought that only applied when you bore out the cylinders. What I have heard is that the 307 cylinders 'should' only be bored once since they are thinner to begin with.
Good luck finding a shop!
J
Jason
Hawaiian-J
70 Longbed, 307, Edelbrock Carb 1404, Edelbrock Intake 2101, Dual Roller Timing chain and gears, 214/214 cam, Comp Roller Rockers, dual Flowmasters.
1999 Chevy Tahoe
2004 Mini Cooper S
71 BMW 2002 - Sold
70ChevyLongbed is offline   Reply With Quote
Old 02-25-2004, 03:23 PM   #6
Perchjerker
Man thats great jimfulco, I work in Henderson!!! I'll run them by and talk with them. I really want to keep my truck as original as possible and the 307 has lasted over 30 years without a hiccup! I guess the 307 block has only average nickel content--anyone know???
Rather be fishin'
Old 03-01-2004, 05:23 AM   #7
1972C10
1972C10's Avatar
I know of a very good machine shop where i get all my stuff done over in greenville. Pm if you need details. Reasonable price full remanufacutred/rebuild.
1972C10 is offline   Reply With Quote
