Old 02-25-2004, 06:19 PM   #1
greasemonkey
greasemonkey's Avatar
new alternator?
I'm pretty sure my alternator's going out. All my lights dim and flicker at lower RPMs, and just recently there is this really annoying high-pitched squeal coming from it.
I really don't care if it is a one-wire setup, I just need a new one. From doing a search, I have found that everyone thinks that internally regulated ones are the best.
What's a good replacement, maybe higher output alternator to get? Should I just go to the parts store and ask the dude behind the counter (that's what worries me, some of those guys will sell you anything, even if it isn't for your car ).
Thanks everyone.
John
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
greasemonkey is offline   Reply With Quote
Old 02-25-2004, 06:22 PM   #2
67chevemall
67chevemall's Avatar
Get it running and take the ground off the Bat. if she dies the alt is dead! Get a internal reg one for sure!
Cheers
1968 Chevy C10 307 3ott fleetside
1967 Chevy C/10 V8, 3spd, fleetside lwb.Sold
1967 Chev C/10 step, 383, M21. SOLD
67chevemall is offline   Reply With Quote
Old 02-25-2004, 06:32 PM   #3
lukecp
Formerly yellow72custom
lukecp's Avatar
If it goes dead when you remove the + battery cable take it into the parts store and they will test it free. If it is OK your voltage regulator is proably shot, and it only costs $12 or so to replace.
My lights also dim at idle, and if i have the high beams, heater fan, and windshield wipers all on at once at idle everything works pretty slowly. I am running the old style externaly regulated alternator. But besides that it works fine.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 02-25-2004, 06:45 PM   #4
dinnut
dinnut's Avatar
check with ragenrat. he used a 84 amp int. reg alt from an 84 camaro. he said the improvement is unbeleivable
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 02-25-2004, 09:58 PM   #5
69K10 Tank
I just did a similar swap. A friends dad gave me an alternator he had laying around. I think it's a 97amp and it really is a great swap. But look around this site, it'll tell you what you want to know. http://www.madelectrical.com/electri...elcoremy.shtml
Cry havoc and let slip the dogs of war
69 K-10, 350, sm465, T221, 33" BFG A/T, drums all around (soon to be discs)
69K10 Tank is offline   Reply With Quote
Old 02-26-2004, 09:57 PM   #6
greasemonkey
Thanks for the link 69K10 Tank. It is a very helpful, well-written article.
The truck didn't die when I took the battery cable off, but I think I will get a newer higher amp one now anyway so I won't have to mess with it later. I am looking at the Powermaster 100 and 140 amp Delco alternators at Summit. I plan to keep the 3 wire setup. Any suggestions on which alternator is the best?
1942 Master Deluxe
1969 C/10
1985 Blazer CUCV
1987 Jimmy
2004 Tahoe
2005 Silverado 1500
2005 Silverado 3500
