Old 03-01-2004, 07:27 PM   #1
RICHARD MORGAN
Dome Light. Door Pins - Triggers
MY DOME LIGHT WORKS GREAT BY TURNING THE KNOB BUT WONT COME ON BY THE DOOR PINS...BEFORE I BUST OUT THE OLD VOLT METER IS THERE SOMETHING SIMPLE IT COULD BE ? DOESNT THE WIRES COME OFF THE DOOR PINS AND TIE RIGHT INTO THE DOME LIGHT WIRING OR DOES THE PIN WIRES GO TO THE LIGHT SWITCH ?
RICHARD MORGAN is offline   Reply With Quote
Old 03-01-2004, 07:35 PM   #2
da-burb
"Ochre Ogre"
da-burb's Avatar
All the pins do is connect to a ground. My first guess is corrosion on the contacts. With the door open try turning the inner post back and forth. If that doesn't fix it then start tracing the white wires.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 03-01-2004, 09:07 PM   #3
Gee_Emm
Try taking the door pins out, remove the wire from them and touch it to a good ground, that will tell you for sure if they are the problem
Gee_Emm is offline   Reply With Quote
Old 03-01-2004, 09:12 PM   #4
tom hand
CCRider
tom hand's Avatar
MOST likely both door switches didn't fail....look for the white wires down by the fusebox and make sure the wire is not broken/unplugged.
72 GMC Sierra SWB almost finished---- 84 Softail
Olive Branch MS
tom hand is offline   Reply With Quote
Old 03-01-2004, 11:04 PM   #5
superfly68
superfly68's Avatar
what year did those start becoming an option?
don't think i have one in my '68...
no longer have a ride, but still a fan!
superfly68 is offline   Reply With Quote
Old 03-02-2004, 01:34 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
69 was the first year for the option.
RICHARD MORGAN, I agree that it is not likely that they both went bad at the same time...have you in fact looked to see that your truck is equipped?
I only ask becouse i knew a dude with a 67 and he was going nuts trying to figure why the light wouldn't come on, turnd out there was no switch available.
