Old 03-03-2004, 03:01 PM   #1
rico_bob
"Treasure the Ride"
rico_bob's Avatar
What is the rear bolt pattern on a 55-59
Help if you know the answer... Does anyone know if there is a bolt pattern on the end of the rear differential flange like there is on the 10-bolt or 12-bolt differentials?
Need to determine the existance (all mine are buried in 12 inches of snow up here) of a bolt pattern on the end of the tube?
For example... the GM 10-bolt has four bolt hole locations. The top bolt holes are 3.125 apart horizontally at the top, and 2.687 apart horizontally at the bottom, and there is 2.437 inches between the top bolt hole and the bottom bolt hole on the vertical.
OR... is the end of the tube fixed to the backing plate by a welded connection???
Help me 'cause I don't like shoveling snow... I am an OLD FART!
Thanks to whomever answers... rico_bob
PS: don't leave it at ZERO as I hate having to answer myself!
If you think you can you're right. If you think you can't you're still right.
Trucks: '56 SWB; '57 SWB; '63 C-10
Current projects: 1963 Long Fleetside for the wife!
'56 for the daughter.
Visit us at: www.ricos-rods-and-relics.com
rico_bob is offline   Reply With Quote
Old 03-09-2004, 06:37 PM   #2
ShamrockCustoms
Project56 on hold
ShamrockCustoms's Avatar
I'll check the back of the 56 this week and let you know. The shop manual didn't even say what the pattern is....
Shamrock Customs
Forever-in-the-Future Custom Shop
2009 Mitsubishi Lancer GTS daily driver
1956 Chevy Stepside rodstoration on winter hold
ShamrockCustoms is offline   Reply With Quote
Old 03-09-2004, 10:31 PM   #3
rico_bob
"Treasure the Ride"
rico_bob's Avatar
Thanks S'Rock!
Thanks Shamrock! I need the pattern where the backing plate goes. Trying to locate a bracket to install disk brake conversion on stock axle ends. rico_bob
