Old 03-10-2004, 10:27 PM   #1
69ChevyGuy
Question Body Dropping a 69
Does anyone have any information on how to body dropp, shave the dripp rails or making a long bed a short bed....I am about to srart my project...if you know of any web sites that have detaile information or if you have some could you please share...thank you
1969 Chevy Longbed
69ChevyGuy is offline   Reply With Quote
Old 03-10-2004, 11:11 PM   #2
wink_tim
wink_tim's Avatar
Early Classic Enterprises has an article about cutting the long wheel base down to short, dont know about the body drop.
67 SWB
wink_tim is offline   Reply With Quote
Old 03-10-2004, 11:28 PM   #3
Joey-D
City's Articulation Ramp
Joey-D's Avatar
Check out
www.kcinter.net/~anmore/bdrop.html
and
http://www.minitruckin.primediaautom..._tech01a.shtml
and
http://www.minitruckin.primediaautom...2_tech01.shtml
I just did the drop on my cab and it was a headache, easy but headache. But then again thats what it was all about. I did a 4 inch body drop, (pretty extreme drop). First I cut out the floor and mocked it up 4 inches higher, threw a seat in the and hated it, there was no room for my feet and legs and I am a pretty tiny guy. I then cut out the area of the floorboards that are commonly replaced. I dropped the rear floor and tranny tunnel 4 inches, but the foot areas only 2 1/4". Doesn't sound like an inch and 3/4" is a lot, but it makes a world of difference. In order to do that I lower the front frame hangers ( where the cab bolts to the frame) 1 3/4" inch to make up the difference. Then had to fab up filler panels around the floor boards and tranny tunnel. I will put up some pics as soon as I get them scanned. Hope you followed what I said. This was my first body drop so I kinda just made it up as I went. There are tons of varieties though. Also 2" inch is the most reconmended because the leg room, the peddels hit the floor and the steering column linkage get messed up.
85 K90 SWB Rockwells 46x19.5 on double beadlocks 20" lift 305/sm465/NP208 Toy
00 Silverado 2wd SWB 4.8 auto 3/4 drop slamair bags esclade rims Daily Driver
06 Harley Sporster 883 low
19?? Zamboni, Really I own a Zamboni!
"If your gonna be stupid, then you better be tough."
Joey-D is offline   Reply With Quote
Old 03-11-2004, 01:06 AM   #4
Joey-D
Joey-D's Avatar
Arrow points to orginal bracket holes, if I remember right, I reused the bottom 2 holes as my new top holes and drilled 2 new holes. Also brackets were L-shaped and had to cut off the top and used grade 8 bolts. Now the floor boards almost, almost, almost rests on the frame rails. The cab support that runs from the lower firewall to the rear had to be highly modifided. Also the rear panel has 4 inches cut out. Instead of cutting 4 inches off the bottom I took it out of the middle to give a more factory look. Its the little things that make the truck. There is no textbook way of doing a body drop so experiment. If you know any old school hot rodders talk to them, They used to do this all the time, but they called it "Channeling". As far as the rain gutters, I cut mine off w/ a sawzall and am just going to weld the pieces back together. Hope this helps, anymore questions I do my best to answer. Just remember this was my first time also!
Old 03-11-2004, 01:09 AM   #5
Joey-D
Joey-D's Avatar
1
Old 03-11-2004, 01:10 AM   #6
Joey-D
Joey-D's Avatar
2
Old 03-11-2004, 01:10 AM   #7
Joey-D
Joey-D's Avatar
3
Old 03-11-2004, 01:12 AM   #8
Joey-D
Joey-D's Avatar
4
Old 03-11-2004, 01:12 AM   #9
Joey-D
Joey-D's Avatar
5
Old 03-11-2004, 01:13 AM   #10
Joey-D
Joey-D's Avatar
6
Old 03-11-2004, 01:14 AM   #11
Joey-D
Joey-D's Avatar
7
Old 03-11-2004, 01:15 AM   #12
Joey-D
Joey-D's Avatar
8
Old 03-11-2004, 01:16 AM   #13
Joey-D
Joey-D's Avatar
9
Old 03-11-2004, 01:17 AM   #14
Joey-D
Joey-D's Avatar
10
Old 03-11-2004, 01:17 AM   #15
Joey-D
Joey-D's Avatar
11
Old 03-11-2004, 01:19 AM   #16
Joey-D
Joey-D's Avatar
12 and done, does anyone know how to include more than one picture at a time?
Old 03-11-2004, 01:22 AM   #17
Joey-D
Joey-D's Avatar
You really can tell the difference on the firewall/ tranny tuneel from the outside. And look where the floor come to on the door now.
Old 03-11-2004, 01:29 AM   #18
Slammed66
Needs a Big Block
Slammed66's Avatar
Id rethink the body drop idea Id sooner go with a drop member ( which I did) or z the frame , for wicked site check out www.ifcustom.com go check out the project espeically the past projects and check out the lowest 70 ive ever seen and they show how to do it , the also built a crazy 63
1964 Short box
On dropmembers and billets
1962 Suburban family cruiser
1972 K10
Slammed66 is offline   Reply With Quote
Old 03-11-2004, 01:39 AM   #19
69ChevyGuy
Thanks for the pictures and the information.....it will help me alot in my quest to body dropp my truck....one more questoin...someone posted that they are selling videos on how to repair rusted parts, shorten a lwb frame and body drop....have you heard of those....if so do you think their worht ordering...i think it's $99 for a 3 hour long dvd...Thanks
1969 Chevy Longbed
Old 03-11-2004, 01:46 AM   #20
Joey-D
Joey-D's Avatar
sorry I fudged up on the first link and this one was the most informative
www.kcinter.net/~anmorel/bdrop.html
Old 03-11-2004, 01:47 AM   #21
boraxman
Keepin an eye out
boraxman's Avatar
Damn Joey-D, youve been busy on that truck....and to think theres people out there worried about cutting the dash for a stereo!
1970 Chevy C10 SWB 5.3
1996 Toyota Tacoma SR5 4x4
2007 Vespa GTS 250 Scooter
ZIP 91351
boraxman is offline   Reply With Quote
Old 03-11-2004, 01:57 AM   #22
Joey-D
Joey-D's Avatar
Almost everyday, hope I don't get burned out to quickly, next after replacing the back wall of the cab, its destroyed from years of someone not tieing down there cargo, cab corners, rockers, footwells, and dog ears (lower A pillars) and a custom inner rocker to raised floor, shaving the firewall and stripping the cab for paint; I am moving on to a 4 link rear (maybe) and a narrowed rear end. I have already narrowed the frame w/ a custom rear frame I built. READY FOR STEAMROLLERS!!!!!!!!!!!!!!!!
Old 03-11-2004, 02:10 AM   #23
ol skool 68
turnin wrenches
ol skool 68's Avatar
wow joey-d looks good and to the comment about people getting pissy about cutting the dash, the way i look at it, i am just glad to see people saving these trucks from crushers, no matter how they decide to restore or rod them...........
69chevyguy: you should be able to find alot of help to almost all your questions from this board, this is the best board i have ever been to, GOOD LUCK with your truck keep us posted!!
BBB
"three can keep a secret if two are dead" -unknown hell's angel-
D.M.C. -FF-
68 SWB full frame off (project ol skool)
2000 s-10 formally bagged but now my daily driver...
ol skool 68 is offline   Reply With Quote
Old 03-11-2004, 03:09 AM   #24
Joey-D
Joey-D's Avatar
The dash was a nightmare when I got it, the guy had roughly (i mean the cut and not the size) cut a 10 x8 hole for the stereo. Then he took another piece of metal and screwed it in with self tapping screws. I have a picture somewhere.
Old 03-11-2004, 04:10 AM   #25
Nate003
i'm bodydropping my 67 shortbed, but instead of the oldschool method that joey-d is going with (which i've done on minitrucks) i'm gonna go with the stock floor bodydrop where you don't cut up the cab, you just cut the frame however much you wanna bodydrop it and put box tubing in it for strength and then lower the cab mounts, seems alot easier and you don't loose any room.
Nate003 is offline   Reply With Quote
