Old 03-11-2004, 08:11 PM   #1
tandm1999
front suspension help
does anybody know or has any body swapped an early 60's front cross member for a late 60's early 70's front suspension and cross member
im wondering if the cross member from a 1962 will interchange with a crossmember from 1970 any info would be appreciated
tommy
tandm1999 is offline   Reply With Quote
Old 03-11-2004, 10:08 PM   #2
zenish
i swapped a 1980 crossmember into a 64.is your truck torsion bars in front?
1964 c10 short step
1962 econoline van
1989 rs camaro
2006 yamaha vino 125
1975 goldwing
zenish is offline   Reply With Quote
Old 03-11-2004, 10:14 PM   #3
tandm1999
front suspension
yes i have torsion bars but i want to change all of it including the crosmember swap the bars for the coils bla bla bla what did u have to do any pics
tommy
Old 03-12-2004, 09:46 AM   #4
rich62step
crossmember
I swapped the front suspension out of my 62 1/2 ton and used a front crossmember from a 75 chevy 1/2 t. It fit pretty well on the frame, but only 6 out of 14 bolt holes lined up. the other holes I had to drill out, it isn't that bad of a job. The 62 frame was about 3/8" shorter (vertical) than the 75 frame but I shimed up the frame to match the height of the crossmember so I could get the top two holes drilled in the frame to bolt it up correctly. I think 73 - to 87 will work for you. Then you also get disc brakes on the front and alot cheaper parts to redo the front suspension. Hope this enough info. for you. Rich
rich62step is offline   Reply With Quote
Old 03-12-2004, 09:20 PM   #5
PJ_STYLES
Rockers1/2"off the ground
PJ_STYLES's Avatar
I recently swapped my 62 front suspension for a 64 suspension. None of the holes lined up on the swap most were out 1/4" So i slotted some holes on the frame and some on the front crossmember and it fit not to bad. I also have a 73-87 front crossmember i was considering but alot of holes or all of them not sure won't line up either, plus i still wanted to keep the 4 way drum brakes.
1962 fleetside: bodydropped,shaved,bagged,custom 64 suspension,clear taillights,custom aluminum parts,rollin on 100 spoke player wire wheels. http://www.finelinedesignz.ca
PJ_STYLES is offline   Reply With Quote
