Old 03-19-2004, 01:48 AM   #1
Lynx
Lynx's Avatar
Striker Bolt
Well the door slaming is starting to anoy me so i got to looking at the striker and it looks like its not far enough out. Question is can i use just a big washer in there to make the bolt come out farther so it doesnt rub on the door? Or is it more a problem with the door?
The door looks like its in the opening straight and it has no play when lifting on it.
Ben
1983 Silverado SWB 305
2002 Silverado Extended Cab 5.3
http://members.shaw.ca/bkennett
Lynx is offline   Reply With Quote
Old 03-19-2004, 02:03 AM   #2
Lynx
Lynx's Avatar
Here is a pic, it looks worse then it actaully is. It was really tight when i tried to loosen it so i had to use a pipe wrench which cut it up a bit but most of it was just paint over spary so it makes it look bad all chewed up.
But what you really need to see is the red circled area. It has worn down from not being in far enough when shutting the door.
Ben
Old 03-19-2004, 03:08 AM   #3
67_SS396
Looks to me that your door hinge bushings are worn out, not that the striker bolt is in too far.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers
'66 C10 - The new hot rod
'77 3+3 Dually - 12 valve 4wd conversion tow rig project
'28 Ford 2 door sedan street rod
RevLimit Offroad
"Hang on beer, we can do this."
67_SS396 is offline   Reply With Quote
Old 03-19-2004, 03:18 AM   #4
apstguy
LED King
apstguy's Avatar
Those things are a booger to get out especially if the torx slot is stripped.
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 03-19-2004, 03:29 AM   #5
ocbaud
Garage Queen Material
i can only imagine
ocbaud is offline   Reply With Quote
Old 03-19-2004, 07:20 AM   #6
MylilBowTie
Right turn Clyde
MylilBowTie's Avatar
That's where a big Kentucky fit all works
1974 C25 LWB: 454 4bbl Carb / TH400 / 3.73
1992 Camaro RS 305 TBI
MylilBowTie is offline   Reply With Quote
Old 03-19-2004, 11:56 AM   #7
Grim Reaper
I agree. The door is dragging on the latch and it's not supose to. With the door just open lift up on it and see how much it moves.
Help section at the parts store has a hinge repair kits.
If it's no slop then the striker needs to be moved down but I think your going to find it's hinges like 67-ss396 said.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
Old 03-19-2004, 12:36 PM   #8
rolson1039
im betting that the door hinge is off a hair with play in it.sometimes its easier to have a buddy move the door up and down whole you look. a good vise grip will get the striker out if its stripped in the torx part. they sell tose too at help i believe
so many trucks so little time!!!
rolson1039 is offline   Reply With Quote
Old 03-19-2004, 02:23 PM   #9
shavedchevy
shavedchevy's Avatar
yeah, I changed the bushings in my hinges, and know it closes easier now than when it came from the factory. I almost slam it too hard sometimes.
Dennis
shavedchevy is offline   Reply With Quote
