Old 03-19-2004, 01:29 PM   #1
Bluegoose972
Van Tilt Installation
Purchased a van tilt from one of our board members, ROD. Thanks ROD for the fast shipment.
Anyways, now I'm trying to get it installed. Is there a good way to remove the rubbers and flange that bolts to the firewall and reinstall on the new tilt? I have seen some discussions regarding this installation, but they never address the rubber installation. I saw an article which showed bending the shifter arm down to let the rubbers slide over, but I'm a little worried that I'll just end up buggering up the unit. I could cutt off the arm, and then reweld after installation of the rubbers. Is there a better way?
Rick
Bluegoose972 is offline   Reply With Quote
Old 03-19-2004, 04:09 PM   #2
jamie72
jamie72's Avatar
i always bend the arm down then,make sure all the rubber is on correctly then bend it back straight.
if you break it THEN weld it back on..
good luck
jamie
jamie72
72 BB cheyenne -- Restoration getting started..
member #807
http://www.myspace.com/whitetailobsession
www.antlertalk.com
jamie72 is offline   Reply With Quote
