03-21-2004, 08:39 PM | #1 |
possible stripped out hinge bolts on door
i am or was,in the process of trying to adjust my drivers door to see how my new rockers are gonna fit and i think i may have stripped out the 3 on top....what would be the thing to do,tap those out and go with a bigger bolt?....i dont suppose you can replace that part of the door can you?....the part that is threaded on the door
he who dies with the most toys wins... |
03-21-2004, 08:53 PM | #2 |
PROJECT 7DEUCE
Bummer, seem's like there is enough material that you could tap the hole bigger but keep in mind that you may have to enlarge the door hinge hole's also..
GO BIG GREEN GO DUCKS MEMBER #6377 72 k-5 daily driver 6'' lift 35'' 350-350-205 slowly getting rust free. Project "7DEUCE" check out my build http://67-72chevytrucks.com/vboard/s...d.php?t=267665 Tim Powell..R.I.P EastSideLowlife..... R.I.P.. |
03-21-2004, 10:06 PM | #3 |
CCRider
You could heli-coil it...or just use longer bolts and put nuts inside the door
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
03-22-2004, 01:39 AM | #4 |
what Tom said
The body shop stripped mine, too. Longer bolts with nuts worked great.
good luck, scott
Silence is golden, duct tape is silver. - Scott |
03-22-2004, 05:32 AM | #5 |
ok,thanks guys
