03-26-2004, 12:26 AM | #1 |
About how much should this cost?
I got the driveshaft out and everything and would take it to the driveshaft shop. About how much should it cost to have them install 3 new u-joints and a new center carrier bearing on a two-piece driveshaft?
Thanks Paul D. '78 C20 Scottdale 350ci, 3-speed with granny gear, 14 bolt rear
Paul D. '78 C20 Scottsdale 350ci 3 speed with granny gear 14 bolt rearend My trucks are "Car-Guy safe".......which pretty much means death trap in the hands of a normal civilian. |
03-26-2004, 01:08 AM | #2 |
i am not sure, but a new slip yoke, 2 new u joints, and lenthening my 1 piece shaft was liek $350, i think
so i assume yours would be quite a bit less. |
03-26-2004, 11:37 AM | #3 |
Open ended question.
What joints are they going to use? Brute force is cheaper then a Spicer. Same with the carrier bearing. They going to ballance it ? Place I use would do the u-joints for about $50-60 for Brutes.about $12 more for Spicers. Never priced a carrier bearing so don't know about that.
Grim-Reaper 70 Pontiac LeMans Sport Convertible, worlds longest resto in progress Looking for 71-72 2wd Blazer or Jimmy Project |
03-26-2004, 08:36 PM | #4 |
im getting u joints from napa for like $12 each... the bearing is like $19 but you need to have it pressed.. im figuring maybe two hours labor?? $75 per hour?? maybe $200??? give or take a few $$$
so many trucks so little time!!! |
03-26-2004, 11:43 PM | #5 |
Well, turns out I only needed one u-joint and the carrier bearing and for them to put those two things on costed me 65 bucks.
And no I didn't need it to be balanced.
