today I took the T221 and adapter off my truck (gosh it was a PITA...the "hidden bolts" under the inspection cover of the adaptor drove me bonkers). however, much to my dismay, when I took the adapter and coupler sleeve off, I found that the splines on the out put of the transmission were pretty well worn. Also the coupler sleeve was almost smooth inside on the transmission side. I am attaching some pics, what can I do about this? I do happen to have a spare 4x4 SM465 in the garage, but I don't really want to swap trannies unless its the only thing I can do (i'm working in my gravel driveway...tranny jack = not move). I do know the spare SM465 I have is very low miles...was told this by the p/o, and the output shaft and the NP205 coupler sleeve arent worn at all and look brand new. any advice? thanks...
1969 GMC K2500 ![]() 1996 Honda Accord 2007 Kawasaki KLR 650 |
#2, the sleeve
![]() Join Date: Feb 2000
I know you probably don't wanna hear this but you better switch the tranny and t-case cause those splines aren't going to get any better. The only thing you can do is to change shafts and changing the whole tranny is a whole lot easier than changing the main shaft. I know what it's like on a gravel driveway, did mine the same way.
'51 South Bend Model "9A" '56 Chevy 3600 NAPCO '74 Chevy Cheyenne Super K20-restored on 37's '72 GMC Sierra Custom K2500- in progress '08 GMC Envoy Denali '12 GMC Sierra 2500HD Denali '17 GMC Yukon XL VCCA member #58596 http://www.nohrco.com |
damn, I'm already replacing the transfer case and adaptor so at least it isn't that bad.
When I took my transfer case off, I found a pretty big problem. The gear oil inside was a silvery color because of all the metal flakes that I assume came from the adaptor and tranny shaft. front and rear output seals are shot and leak like a b!tch. there were a small handful of curious looking broken metal pieces in the bottom of the case, and some more on the input shaft of the transfer case itself. i don't even know what they are from ![]()
put a piece of ply wood or two under there to move your jack around on.... might make things a little easier...whats 20 bucks to make a job a HECK of a lot easier...
I agree with the above, better off just putting in the other tranny. Good luck and get that piece of plywood - it will make your life alot easier.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
the easiest thing to do it to yank the tranny and swap it. as stated go get yourself a nice sheet of plywood the jack rolls a lot nicer on that not the mention it doesnt hurt near as much to lay on rocks poking you in the back sucks
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
