Old 03-26-2004, 11:11 AM   #1
mike63078
Widest rear rims and tires
Ok guys I did a search and found that on 67-72's everyone siad you can run a 15x12 with 7.5 BS on the rear of our trucks with just a mini tub. Is this the same for ours? I would like to run a the widest tire I can out back and have to do body work to the bed anyway so might as well do it before i start. Let me know what everyone thinks
thanks
Mike
mike63078 is offline   Reply With Quote
Old 03-26-2004, 07:36 PM   #2
kevhill85
91 SWB 383
kevhill85's Avatar
i'm running a 15x10 with 4.5 bs .
96 2dr Tahoe protruning LS1 347/4L60L, PSI harness, body dropped, 4link, 6lug conv, narrowed rearend, Schoenfeld headers, 2600 stall, 317 heads milled .040,
http://photobucket.com/albums/q169/k...ahoe prostreet
kevhill85 is offline   Reply With Quote
Old 03-26-2004, 07:49 PM   #3
SCOTI
SCOTI's Avatar
Actually, on 67-72's you can go up to 14" wide. I had 15x14's w/9.75" backspacing, a stock width 67/8 12bolt, & trailing arms. This combo used a 31x18.5x15 Mickey Thompson Sportsman. I stretched my bed tubs all the way to the frame (they're approx 20" wide). You cannot run this set-up w/lowering blocks.
With the 73-up models, you can't go that wide w/o moving the leaf springs inboard of the frame rails. If your not moving the springs, but widen the wheel tubs, you could prob fit 12" wide wheels w/about 6-6.5" of back spacing.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 03-26-2004, 10:14 PM   #4
low 84
low 84's Avatar
you might be able to tuck a 15.5 inch wide tire on a 15x12 with the leaf springs there but you'll have to do some measuring on your own to get your back space right casue it will be pretty close
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 03-26-2004, 10:36 PM   #5
TIMSPEED
TIMSPEED's Avatar
With a flip kit out back, I run 17x9½ with a 5½" backspacing. I have a set of 255/55's on their right now, but I PLAN to put 275/50 17's on soon.
I have a few cars...
See Them Here
TIMSPEED is offline   Reply With Quote
Old 03-27-2004, 12:05 PM   #6
1FaastC10
1FaastC10's Avatar
uh, Tim, we're talking WIDE tires here. the tires that came stock on my 91 are wider than the ones you mentioned.
1FaastC10 is offline   Reply With Quote
Old 05-13-2004, 08:13 AM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
:p
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 03-29-2004, 02:52 AM   #8
highboy_04
highboy_04's Avatar
your truck came stock with rims that are wider than 9.5"?
'67 c10 350/th350
highboy_04 is offline   Reply With Quote
Old 05-12-2004, 11:01 PM   #9
mike63078
any other input i am getting ready to buy, here are my choices in a prostar
15'' x 12''
Rear Spacing: 4.5''
15'' x 12''
Rear Spacing: 6.5'' $199
or
15'' x 12''
Rear Spacing: 7.5''
also what size tires can i use? I will be streching my wheel wells so let me know
thanks
mike
Old 05-12-2004, 11:37 PM   #10
C-10volvo
C-10volvo's Avatar
i have fitted a 22 by 12 inch wheel with a 325/40/22 tire with no clearance issues. it has no drop either.
Ken Morgan
For fun: 1964 Volvo 122
For slow: 1984 Chevrolet C-10
For everything else: 1997 BMW M3
C-10volvo is offline   Reply With Quote
Old 05-13-2004, 07:25 AM   #11
mike63078
what kind of back spacing?
