Old 03-26-2004, 11:24 AM   #1
chargedstang89
Truck Died...Won't Fire!!
Last night, I went mudding at my buddy's farm and all was well. Fired it up to go to work this morning and it fired right up, then died. It won't restart and while cranking, it won't even "hit" at all.
Any clue why this would happen? I just put a new cap/rotor, wires & plugs in it. I also just recently set the timing as well. I checked for mud and my motor was clean, so that's good. Anyone have any ideas?
chargedstang89 is offline   Reply With Quote
Old 03-26-2004, 11:27 AM   #2
Grim Reaper
Bad canooter valve.
Hay buddy, throw us a bone here.
Some important information like year, engine stuff. induction etc. Put it in your sig or put it in your stuff with the avitar.
What might be a common cause for this problem on a 88 may not be the common cause for this problem on a 78.
Grim-Reaper
70 Pontiac LeMans Sport Convertible, worlds longest resto in progress
Looking for 71-72 2wd Blazer or Jimmy Project
Grim Reaper is offline   Reply With Quote
Old 03-26-2004, 11:34 AM   #3
swervin ervin
You get what you pay for
swervin ervin's Avatar
Out of gas.
Mike
1985 Chevy C-10
swervin ervin is offline   Reply With Quote
Old 03-26-2004, 11:39 AM   #4
Grim Reaper
Originally posted by swervin ervin
Out of gas.
hehehe That's my guess too.
I'm betting it's a TBI and pump ate it.
Grim-Reaper
Old 03-26-2004, 02:29 PM   #5
toytruck
5-7 dropped 87 CC Dually
toytruck's Avatar
Ground wire for the elec. pump? Need more info!!!!!!!!!!!
I rather be in my 77 Sanger Picklefork Jet Hydro!
toytruck is offline   Reply With Quote
Old 03-26-2004, 03:40 PM   #6
chargedstang89
re
Sorry guys...I was in a hurry here at work and forgot to tell you everything.
It's an 85 GMC K1500
It has a brand new GM Goodwrench Crate 350 with 15,000 miles. The engine is still bone stock.
Edelbrock 1904 Q-Jet Carb
Stock replacement distributor
Last week, I put new plugs wires, cap & rotor on it as it was running a little rough. This smoothed it out. This weekend, I pulled the intake & valve covers to replace all gaskets because they were leaking oil pretty bad. The well plugs have been leaking in the carbureator, so I coated the bottoms of them with J.B. weld as the fuel was leaking through the solder (no...I didn't get j.b. weld where I wasn't supposed to) hehehe Although last night, it did seem like I was smelling kind of a raw fuel smell when the truck would idle.
Anyways, this totally has me baffled because it ran perfect last night when we were out playing on my buddy's property. it fired right up this morning, I backed up, then it just died and now it won't fire. If you need anymore info, let me know.
Old 03-26-2004, 04:30 PM   #7
swervin ervin
Start by swapping out the module in the distributor. First check to make sure you are getting power to it. If it's not even acting like it wants to crank, I'd bet money it's ignition related.
Oh, make sure you have gas getting to the carb too.
Old 03-30-2004, 11:17 PM   #8
Ric83
Ric83's Avatar
Kind of sounds like what just happened to may dad's truck Wed. night while coming home. It would crank but would not start. Had to spark to the plugs. It was the module in his distributor.
Ric
'83 Silverado SWB Fleetside
Here she is
Ric83 is offline   Reply With Quote
Old 03-31-2004, 12:02 AM   #9
86 Red_Bowtie
86 Red_Bowtie's Avatar
Try the pic up coil on the bottom of the ditrubutor. Mine did the same thang once and that was the problem.
Sean
Midwest All Truck Nationals, Riverside, MO - 2008 - 2015
86 Red_Bowtie is offline   Reply With Quote
Old 03-31-2004, 12:10 AM   #10
mike reeh
5 day ban, learn to behave.
mike reeh's Avatar
before you start throwing parts at it check for
A) FUEL
B) SPARK
you will see gas shooting out of the accelerator pump nozzle when you open the throttle by hand. This will be enough gas to get the engine to start at least for a second. If there is gas, check for spark. Get a spark plug and plug it into one of the plug wires while you crank it and hold the electrode to a good ground source (exhaust manifold bolt, or something) and watch for a nice blue spark. If its not sparking its probably distributor related. Check for 12volts @ the distributor then look for obvious malfunctions inside the cap then replace the module then pickup.
should be really easy to track this problem down.
good luck
mike reeh is offline   Reply With Quote
