Old 04-02-2004, 01:07 AM   #1
68step
steering column
I just bought a 68 swb step side. the guy that had it put a (looks like mid 80s)steering column in it but it moves up down all around.It also has the pull bar type e brake. Is there some type of a clamp that clamps that besides the e brake bracket. Thanks in advance.
95 sfa 38.5 swamper TBI vortech
68 chevy stepside
68step is offline   Reply With Quote
Old 04-02-2004, 09:19 AM   #2
JimKshortstep4x4
Talking
The column should be clamped in two places, at the floor and underneath the e-brake. You may have to put another column in it as the later model may not bolt up without modifying.
Jim
Old 04-02-2004, 09:47 AM   #3
MOTHERTRUCKERS
Under the e brake bracket is a strap held in with 2 bolts that hold the column tight to the dash, out on the firewall is a plate bolted to the firewall with a rounded perch that a band clamp fits on to hold the column. Any 2" dia column will usually fit these trucks if they have no ignition switch in them with a little work.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 04-02-2004, 02:16 PM   #4
68step
thnk you very much for the info.
68 chevy stepside
Old 04-02-2004, 08:48 PM   #5
68step
It has the band thing on the firewall. But no clamp under the dash. Does anyone know where to get the clamp from? Ive looked in a couple catalges but couldnt find it. thanks
68 chevy stepside
Old 04-03-2004, 02:44 AM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
If it is a late model column (with key and wiper switch) then a stock one probably won't work due to the larger diameter of the later column.
Old 04-03-2004, 04:52 AM   #7
68step
OK it is the later model with the key and wiper switch. Maybe Ill just switch it back.
68 chevy stepside
